![]() Drives: '99 Yaris Join Date: Jul 2010
Battery drain by radio circuit
The circuit which includes the radio and cassette player in our old '99 Yaris is drawing almost 200 milli-amps when the engine is switched off.
Naturally, if the engine isn't run for a day or two, the battery can go flat - not good. (From what I've read, a car - when all the electrics are switched off - shouldn't draw more than 50 - 75 mA from a battery?) When I take out the relevant fuse - a 15 A - the drain on the battery drops to about 20 - 40 mA, if I recall correctly. The down-side of taking out the fuse is that I can't have any music when I drive. But, perhaps more importantly, this circuit also powers the headlight beam indicator - so it would be good to get it fixed. Has any one experienced this sort of problem before? I just wanted to make this enquiry, before trying to delve any deeper myself. The car is fairly old. Is it likely that the radio is the culprit? I need to double-check what else is on the circuit. |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
in my experience it's the cig lighter...it's often attached to the circuit and usually i find a gum wrapper or something in there. just enough to pull current but not blow the fuse kinda thing...
any way, check the C&D printouts and find out what all's on the list for that circuit and start unplugging stuff. see what makes it drop most n leave it unplugged, or trace it out for a short |
Cheers. I'll try to look into it tomorrow.
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| ATL, I want to trade my Upgraded built in radio... | matthewallanstill | Southeast | 2 | 03-28-2009 06:29 PM |
| Battery Current Drain | karlb | General Yaris / Vitz Discussion | 3 | 12-09-2008 04:28 PM |
