#73 |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Wow, did not know this. Sounds like a great tip!
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
#74 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Do this if you don't have a torque wrench . Take a medium to fine SHARPIE permanent magic marker with black ink and draw a line on the drain fill plugs and the tranny itself so they line up . Then write D.P. ( drain plug ) or F.P. ( filler plug ) on the plug so when you put them back in you'll be using the same plug so they will line up . Can tighten it just a bit more beyond the mark on the tranny , if needed .
#75 |
Went out to take the pic for my avatar just now and drove to a different parking place in the sun. I went from driving around in first to putting it into reverse to back into the parking place. Slight grind in the gear as I placed it into reverse. *shrug* hopefully the gear oil change will help.
#76 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
inside the engine bay on ur tranny check ur linkages and grease/oil where felt needed. my 5th and reverse were stiff and toyota did this for me now all gears go with with ease
#77 |
![]() ![]() Drives: Red 2007 Yaris Sedan Join Date: Apr 2007
Just wanted to say thanks OP for posting this, I am doing a ton of 60k maintenance on my car, new plugs, new brake pads, and now thanks to you i have new tranny oil :-) much obliged!
#78 |
![]() Drives: 2007 Yaris Sedan Join Date: Jul 2010
Another thanks to the OP for this very helpful thread. I just passed 100,000 miles on my '07 and even though the dealer said that the transmission oil didn't need to be changed, I went ahead and bought some MT-90 from amazon.com and changed it today in addition to the coolant. Many thanks for this forum.
#79 |
Great thread and thx for the great pic's
#80 |
![]() ![]() Drives: 2008 toyota yaris Join Date: Mar 2011
I just changed my trans fluid today at 55,400 miles, Tranny fluid looked as good as new when coming out. No metal flake look to it. Installed 75w-90 Royal Purple and went for a drive. Well don't waste your 30 bucks on this oil. My car did shift better. On cold days before it would be stiff or hard to get into gear down shifting to second and to first. It is better, but not as good as I was hoping. In 5,000 miles when I change my oil I will be going to MT-90 and will update you guys on how that performs.
08 toyota yaris with some big tires lol 02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
#81 |
Big difference , when cold shifting and no clunking into reverse . After the change , take it out for a spin and work through all the gears , including reverse . Not long after you'll be in for a smooth transition .
#82 |
drove 70 miles round trip from home to work than back. Still not as impressed as what i figured it will be. like I said I will change it again at 60,000 and try red line. When I first took off this morning it was about 40* out. It did shift amazing when the car was cold. But after about 10 miles it felt almost as if it was the old fluid. Oh well. It would be nice if it got better after a few more miles. Time will tell.
#83 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Can't see Pics.
#84 | |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
Does anyone know? |
#85 |
![]() Drives: 2007 Toyota Yaris RS Join Date: May 2007
Brief necro, but wanted to thank the OP for the informative DIY guide. Drained and filled my RS 5MT with Redline MT-90 today and even after only a dozen km of testing, it feels great. Shifts are smoother than on the stock gear oil, and the entire process only took an hour or so.
For those with Tanabe DF-210's installed you can reach both the drain and fill plugs without jacking the car, but it's pretty cramped. I did have to loosen the under-air dam shroud to get good access to the bolts. Interestingly, I loosened the filler bolt with an air tool and, not knowing that the bolt only had about 3/4" of thread on it, took the entire thing off in one swift go. The result was more than a cup of gear oil spilling out. The two quarts I added after the drain got me right to the proper fill (i.e. right at the bottom of filler plug), but it makes me wonder how I got so much oil in there before. tl;dr, Redline MT-90 is great so far, process was simple and cheap for DIY, lowered cars can be refilled without jacking, though it is more difficult. |
#86 |
Yes Thanks OP!
Redline MT-90 is the BEST! GL-4 all the way! Just did another Transmission fluid change. I found it easier to remove the entire air box to gain access to the fill plug from the top with a funnel and tube. |
#87 | |
Torque wrench complete overkill for something like this however. Manual says something like "Torque the oil filter with a torque wrench. If you dont have one take it to your dealer for proper torque." Just intimidating the public Im afraid. The bastards. Actually torqueing the OF to their spec will prolly result in it being nearly impossible to remove IME. |
#88 | |
![]() Drives: Nautical Blue Yaris Sedan 5spd Join Date: Jan 2007
I changed the gear lube in my 07 sedan at 100k with mt90. The original fluid looked as good as new... |
#89 |
Drives: toyota yaris Join Date: Sep 2011
Great info. But that only drains 1 3/4 qts. of fluid and there is 4.9 qts. so how do you get the rest out?
#90 |
![]() Drives: 07 yaris hatch 95 del sol Join Date: Sep 2011
Thank you very much for this how to thread sir! Just changed my fluid a few minutes ago and it worked great!
07 yaris LB 95 del sol S 98 civic LX |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 01:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
