Old 11-02-2010, 01:35 PM   #11
Hershey
Do this if you don't have a torque wrench . Take a medium to fine SHARPIE permanent magic marker with black ink and draw a line on the drain fill plugs and the tranny itself so they line up . Then write D.P. ( drain plug ) or F.P. ( filler plug ) on the plug so when you put them back in you'll be using the same plug so they will line up . Can tighten it just a bit more beyond the mark on the tranny , if needed .
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
