Old 10-25-2010, 01:49 PM   #1
elmo
WFO
elmo's Avatar
Drives: 2008 hb
strange noise
OK i got a noise in the right front sounds like a rock in a hubcap if you know that sound, and no i don't have hubcaps, it is only at slow speed i looked in the disk guard nothing there
HELP !!! it is driving me nuts
elmo is offline   Reply With Quote
Old 10-25-2010, 02:25 PM   #2
DARK AGE 53
Drives: 2009 Yaris Onyx
maybe lug nuts loose, hub assembly bearing going bad?
DARK AGE 53 is offline   Reply With Quote
Old 10-26-2010, 12:56 AM   #3
DARK AGE 53
could also be front sway bar end link?
Old 10-26-2010, 03:47 AM   #4
henry33
Drives: yaris1.33
I had the same it was very annoying and finally I have found the reason the bonnet rattles in the lock since the rubber backstop have been screwed all the way down ! try to screw them up maybe it will help also for you
henry33 is offline   Reply With Quote
Old 10-26-2010, 05:24 PM   #5
elmo
WFO
elmo's Avatar
Drives: 2008 hb
Thanks all,
no lose lugs
its not the bonnet
i will check the sway bar
this thing is crazy sounds exactly like a rock rolling around in a hubcap but i don't have them so i know it's not that
Old 11-21-2010, 11:49 AM   #6
pz's yaris
Drives: 2008 Black Sand Pearl HB
I am having the same problem but coming from the rear (at least that's where it sounds like it's coming from). I just had it at the dealer for oil change yesterday and they stated they didn't hear anything... I swear they never hear anything. Anyways, I came here to see if anyone else was experiencing this. I am bound and determined to get to the bottom of this so I will certainly share my findings if I can get a mechanic to confirm the noise I am hearing and fix it!
pz's yaris is offline   Reply With Quote
Old 11-22-2010, 08:00 AM   #7
elmo
WFO
elmo's Avatar
Drives: 2008 hb
I FOUND MY PROBLEM !!!!!!!
there was a small rock in the slot on the back side of the right front disk, at slow speed it was falling out and hitting the disk guard then bouncing back into the slot at speed the centrifugal force held in in place. it was just big enough that it wouldn't fall out had to pull it out. that sound was driving me nuts. at least now i know what it is if it ever happens again !!!
Strange noise! mario98c Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 09-24-2010 06:49 PM
Strange noise? Taiyaki Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 08-29-2009 04:05 AM
strange noise before the car stops dani1983 DIY / Maintenance / Service 14 08-15-2009 12:56 PM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 09:37 PM
strange noise nisyota DIY / Maintenance / Service 7 03-05-2009 09:39 PM
