Old 08-25-2009, 10:38 PM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
Strange noise?
So I put on some wide 18x8 wheels, It has a +40 offset so there isnt any rub, even at full turn. But I noticed that when I hit 30mph I hear this noise that sounds like a jet engine or somthing! Im sure its not my car, because the only thing I did was change my wheels.
I can try and get the sound on video. might be alittle hard though.
The only thing I did different from my other wheels was that I put the plastic rings on the inside of the center caps. idk why but they said its a good thing to do.
Old 08-26-2009, 01:11 AM   #2
Are you talking about hubcentric rings?
Anyway, check your lug nuts now. They might be loose, or have loosen.
Old 08-26-2009, 01:37 AM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Not road noise from low profile tires on big rims?
Old 08-26-2009, 01:37 AM   #4
Taiyaki
アキバ製
Taiyaki's Avatar
I think so, im not sure what they are called.
Ok i just checked my lugs and they were still tight.
Old 08-26-2009, 01:38 AM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
No, this sound only come when Im going around 30mph, then goes away.
sounds like a lightsaber or somthing that shouldnt be coming from a car... ><;;
Old 08-26-2009, 02:08 AM   #6
So, you are sure that all 16 lug nuts are on tight? I had that sound (sounds like a deep light saber or a helicopter) a minute or two before I lost one of my lug nuts on the freeway and the rest were loosened. Also check that the rings are on right as they may be causing the rims to vibrate/wobble if they not on correctly.
Old 08-26-2009, 05:58 AM   #7
Taiyaki
アキバ製
Taiyaki's Avatar
Im sure that all 16 lugs are tight at 75lbs. Also Im pretty sure I put the rings on right. There was like only one way that made it go in perfect.
Still dont know what the noise is but it worries me. ><;;
Old 08-26-2009, 08:19 AM   #8
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I have this same noise and I just thought it was my bigger tires ... maybe I should check my lugs LOL
devinlamothe is offline   Reply With Quote
Old 08-26-2009, 03:19 PM   #9
Oh, another thing, are your tires unidirectional? I know when I had my Parada Spec-2's, they made an identical sound when braking (tires biting into the road).
Old 08-26-2009, 06:15 PM   #10
Taiyaki
アキバ製
Taiyaki's Avatar
Hmm not sure, but the I hear the noise just driving, not just from braking. once I get under 30mph it goes away.
Old 08-26-2009, 06:38 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
bad tires
or one of your wheel bearings is already taking a dump..
Old 08-26-2009, 06:48 PM   #12
Taiyaki
アキバ製
Taiyaki's Avatar
bad tires
The tires are pretty new. Is there somthing I can do to check if it is?
Old 08-26-2009, 08:04 PM   #13
supmet
Drives: 2007 4 Door Yaris
How much do your 18x8s weigh?
And wheel bearings aren't in the tires..
Old 08-26-2009, 08:24 PM   #14
Taiyaki
アキバ製
Taiyaki's Avatar
Its like 19lbs
Oh yeah I know its not, I was answering his question about bad tires
Old 08-26-2009, 09:49 PM   #15
Taiyaki
アキバ製
Taiyaki's Avatar
Ok so here is a clip of the sound.
I tried to isolate the sound the best I could. I used my mic I use to recordings and it did a pretty good job of picking up the noise.
Anyone know what the sound is?
Old 08-26-2009, 10:10 PM   #16
hmmm, the sound I heard once or twice on my car doesn't sound like that.
Old 08-26-2009, 10:22 PM   #17
Taiyaki
アキバ製
Taiyaki's Avatar
Yeah I never heard somthing like that before too. I worries me greatly. ><;;
Old 08-27-2009, 10:55 PM   #18
Taiyaki
アキバ製
Taiyaki's Avatar
Well I took them off and checked it out, but didnt see anything strange. any know?
strange noise before the car stops dani1983 DIY / Maintenance / Service 14 08-15-2009 11:56 AM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 08:37 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
strange noise nisyota DIY / Maintenance / Service 7 03-05-2009 08:39 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
