Old 02-01-2011, 07:56 AM   #1
Craig
Drives: Toyota Yaris 02 Auto
Variable Valve Sensor Error
Good afternoon all.
I took my girlfriends car into a garage (Toyota Yaris, 02, Auto) after the engine warning light came on. The plugged it in, and came back to say that the error code it threw up means that it is something to do with the Variable Valve Timing. They have told me that they need to replace both the Variable Valve Pump and the Variable Valve Pump Sensor, at a cost of £200 plus labour. Howevey, when pressed, they also admitted that this may not clear the fault, so I should also consider changing oil and oil filters.
I am reluctant to pay in excess of £500 for them to do work which may or may not fix the problem.
Surely they can give me a better diagnostics than this, something a little more concrete than "probable... maybe" etc.
Has anyone else had this problem, is it dangerous to drive the car whilst this error code appears?
I am a complete novice when it come to repairs, diagnostics etc so any help / advice would be greatly appreciated.
Kind regards,
Craig
Craig is offline   Reply With Quote
Old 02-01-2011, 11:29 AM   #2
Can you find out what the actual error code was?
Also, which engine does your Yaris have (1.0L, 1.3L, or 1.5L)?
Old 02-03-2011, 05:23 PM   #3
markweatherill
Drives: Toyota Will Vi
The main components associated with the variable valve timing are the 'oil control valve' and its associated filter which would be the things to look at first. And inside the engine, the camshaft sprocket. I'm concerned about the terminology the garage has used as it doesn't sound like they are familiar with this system!
(on various forums I've been reading that a simple clean of the OCV filter may be all that's needed in similar cases. I've been reading up on the subject recently)
markweatherill is offline   Reply With Quote
Old 02-04-2011, 05:15 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
did you hit the oil control valve with a hammer while installing a lightweight pulley? ;)
Old 02-04-2011, 06:02 PM   #5
yaris2010RS
yaris2010RS's Avatar
u did it too?
Old 02-04-2011, 08:58 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by yaris2010RS View Post
u did it too?
nope, but i've had dozens of people ask me to sell me one, right after they installed their awesome-super-power pulleys...
Old 07-11-2011, 12:52 PM   #7
aruester
Drives: 2009 Yaris 3D
LMAO! That would be me! Retensioning the belt and SNAP.... oops.
aruester is offline   Reply With Quote
Old 07-16-2011, 07:59 PM   #8
yaris2010RS
yep same thing i did..... i sent a few ppl these that i had cleaned out from the local junkyards
Old 07-17-2011, 09:46 PM   #9
auxmike
auxmike's Avatar
Is this it?
It's real easy to bust off the black connector when fooling with the waterpump or alternator.
File Type: jpg $(KGrHqMOKpgE3uV!lH27BOB!TQKR+!~~_12.jpg (18.3 KB, 170 views)
Old 04-30-2013, 07:36 PM   #10
yak
yak
Drives: 2007 5 dr yaris
Oil Control Valve stuck in head
I realize this is an old post but...
I'm replacing my OCV for typical the reason, yep; dinged it changing the alternator belt.
When I attempted to remov the OCV the solenoid and the actuator separated...bugger...poor design in my opinion looking at the head there is flange which I cant get a grip on but I can remove the plunger that is inside the actuator dya think an easy out (screw extractor) will work to remove it ?
cheers & thanx
yak
yak is offline   Reply With Quote
Old 04-30-2013, 08:56 PM   #11
YarisSedan
Drives: 08 Yaris Sedan
Something as simple as low oil or incorrect oil can cause this fault. I would try a oil change first and clear the fault and see if it comes back
Old 05-01-2013, 04:31 PM   #12
jcboy
Drives: Sedan 07
i suggest always try with the cheapest possible culprits first. look at the factors of vvti error throwing a CEL. it can be as complicated as the sensor, a bit simpler a stuck valve, or as simple as wrong oil viscosity.
yes that means an oil change would be cheapest.
Old 05-09-2013, 12:24 AM   #13
yaitsme
Drives: 2008 Yaris
Welcome to the club. I did the same thing when I went to tighten the belt for a squeal sound when starting the engine. The solenoid is very easy to replace, the picture that auxmike posted above is the part. 1 bolt and it comes right out. Try to get it from local junkyards like yaris2010rs did. Its very expensive from the dealer.
yaitsme is offline   Reply With Quote
Old 06-22-2013, 03:29 AM   #14
yariseggvvti
Drives: Yaris Hatchieback
Originally Posted by auxmike View Post
Is this it?
Found oil leak from this valve. It seems like the O-ring is bad.
Has anyone replace this valve?
Thanks!
yariseggvvti is offline   Reply With Quote
error code, pump, sensor, variable valve timing
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
gude-head-1NZ-FE GnomeBody Performance Modifications 222 03-25-2011 02:32 PM
Ferrea valve upgrade kit cali yaris Micro Image 4 07-28-2010 11:52 AM
Want to connect a sub/amp to your factory HU? Navone N-85V Variable LineOut Convertor rningonfumes Items for Sale by private party 0 03-18-2010 10:39 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
