Old 03-28-2011, 03:51 PM   #19
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
But a 1NZ-FE doesn't have hydraulic lash adjusters or adjustable tappets, you should still re-shim the buckets to get the clearances correct.
rob323 is offline   Reply With Quote
Old 03-28-2011, 10:04 PM   #20
Dylan Yap
Drives: Toyota Vios
You need to do this IF you are going for spec higher than what i have. What i using is bolt-on JUN cams 264 - 9.5 mm
Dylan Yap is offline   Reply With Quote
Old 03-29-2011, 03:07 PM   #21
Jason@SportsCar
There are like 16 different OE bucket part numbers (in varying thickness) for use with the stock cams. Build tolerances within the head, valves, cam and bearings are enough to require a bucket change with just a stock cam replacement.
Old 03-29-2011, 03:59 PM   #22
rob323
My point exactly, you can't even use a stock cam from another motor without having to redo the clearances.
Old 03-29-2011, 04:01 PM   #23
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Cool stuff, but yikes: $800 USD per cam is a lot of dough. It is cool to see some NA builds, though.
Old 03-29-2011, 04:03 PM   #24
Jason@SportsCar
I am sure its fine, just send your $30k to me, I will send you a set of magic cams and a cashiers check for the balance.
Old 03-29-2011, 04:12 PM   #25
rob323
No thanks, I'll do it myself so I know it's done right.
Old 04-06-2011, 11:55 AM   #26
vitz rs
Drives: Vitz RS turbo M
Hi Bro, I am driving vitz rs.
just wondering where is your workshop?
vitz rs is offline   Reply With Quote
Old 04-13-2011, 04:25 AM   #27
Dylan Yap
Drives: Toyota Vios
Pmed you my address... great to find someone from SG here
Old 04-13-2011, 10:47 AM   #28
vitz rs
U got mail bro.
Old 04-19-2011, 04:14 PM   #29
rob323
I see these cams are now available on Yahoo Japan.
Old 05-11-2011, 02:58 PM   #30
speed1
Drives: vitz rs
The True
I read all of your stories.
Super Mega cams for 1nzfe.
If u look at Jun site there are only 2 specs for 1nzfe:
9,0-63 (bolt-on series) and 9,5-66 (regular series).
If 9,5-66 rev limit move e vvt-i manage required
to have best.
speed1 is offline   Reply With Quote
JUN Releases Camshafts for the 1NZ-FE changchewsoon Performance Modifications 53 01-23-2017 08:28 PM
JUN Auto Releases High Lift Camshafts for Toyota 1NZ-FE changchewsoon Performance Modifications 7 02-16-2011 03:46 PM
Gude cams "NOT SO NACHO" xbgod Performance Modifications 77 01-27-2011 01:45 PM
JUN Auto - 1NZ-FE I-Beam Connecting Rods changchewsoon Forced Induction Forum 10 04-19-2010 11:00 AM
GI: Custom Cams lilredrocket Performance Modifications 62 11-13-2009 10:10 AM
