Old 03-22-2011, 06:22 AM   #1
Dylan Yap
Drives: Toyota Vios
JUN Cams for 1NZ-FE
Last week i had successfully install the JUN cams on one of my customer's Belta ( New Vios)
same engine as Yaris 1NZ-FE
here are some picture to poison a bit
Dylan Yap is offline   Reply With Quote
Old 03-22-2011, 08:15 AM   #2
They look like they have a LOT more duration.
Old 03-22-2011, 10:38 AM   #3
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Did it use the stock cam followers?
How does it run?
Old 03-22-2011, 11:08 AM   #4
Dylan Yap
Drives: Toyota Vios
it is plug and play.
dur 66 valve lift 9.5mm
Old 03-22-2011, 12:03 PM   #5
^ before and after dyno would be good to see.
By the way guys, these cams are over $800... EACH.
Old 03-22-2011, 12:55 PM   #6
Dylan Yap
Drives: Toyota Vios
ya thanks to the high jap Yen now sadly. but i am selling them like well in my country even with this price tag
Old 03-22-2011, 12:58 PM   #7
Dylan Yap
Drives: Toyota Vios
Please Note Result varies from car to car, engine to engine.
the car
the Power BHP
the Torque Nm
Thick solid Blue / Green is after tuning
Dotted Blue / Green is before
The test car is a Auto Vios,
Parts on the car:
1) Speed-d 4-1
2) HKS Hi-Power Muffler
3) Unichip Q
4) SS drop in Filter ( Stock Airbox)
5) CAI
Condition of car:
1) Mobil One EO 5000Km old
2) Denso Iridium spark plug (Not New)
3) 92 Fuel ( Last minute try our best to mix with 98 Fuel)
I was happy with 141bhp on crank for a Auto Vios. i expect more for MT vios.
Dyno is Dynopack TCF is set at 1.2 for auto
Old 03-22-2011, 01:34 PM   #8
Looks like a gain of about 14 hp and 20 torque, yes?
I don't think a stock ECU could handle this mod, you'd have to tune the car with management like this Vios was.
Old 03-22-2011, 02:24 PM   #9
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
would you say these cams are tunable for boost? if i got these cams and then later boosted on top of them, could i tune it also? or is the lift and dur on these cams specific to N/A tunes?
Old 03-22-2011, 02:56 PM   #10
Jason@SportsCar
I seem to recall the early posts about Jun cams listing three different sets of specs, with this one being the most mild. My math, and memory, may be a bit fuzzy... But I come up with this as a .354 lift, that is not much more than stock.
This is what is listed on the Jun website.
63 (252) 9.0 9.0 IN IN 1004M-T031 1004M-T031 JPY42,000 JPY42, 000 Can use with stock ECU Can use with stock ECU
EX EX 1004M-T131 1004M-T131 JPY42,000 JPY42, 000
* * The amout of lifts shows the cam lift. * The amout of lifts shows the cam lift.
Old 03-22-2011, 02:58 PM   #11
Jason@SportsCar
Where is the rest of the screen, RPM, AFR?
the car
the Power BHP
the Torque Nm
Parts on the car:
1) Speed-d 4-1
3) Unichip Q
5) CAI
Condition of car:
Old 03-22-2011, 04:24 PM   #12
Here is the data I got when I considered stocking these:
1. 256 duration, 9.0mm lift (Street)
2. 272 duration, 9.5mm lift (NA)
3. 272 duration, 10.5mm lift (Turbo)
Old 03-22-2011, 05:17 PM   #13
ilikerice
ilikerice's Avatar
^woot woot^ thats what i was looking for.. and also, i do remember seeing that in another jun thread
Old 03-23-2011, 02:30 AM   #14
Dylan Yap
Drives: Toyota Vios
i dont do turbo car so i am not sure. this is what i request from JUN, the 3 spec mention
also avaliable.
this one i install is 264dur 9.5mm valve lift.
i want a bolt-on thus i am not going for anything wild. stock lift is 9mm
Stock ECU can run the cams, but advise to add tuning to max on the result.
AFR i am running 13.3 for NA
note i am just sharing...not selling... too far haha
Old 03-25-2011, 11:33 AM   #15
rapev-8
Drives: toyota
also avaliable.
so i will able to run with my basic bolt on and the 9.5mm cam with my stock ecu on my 2010 5 speed?
rapev-8 is offline   Reply With Quote
Old 03-25-2011, 11:52 AM   #16
^ They say so, but do you want to pay $1700 to find out if you get a CEL or not?
I haven't seen an example where they just bolt on the cams, go drive the car hard, and show that the stock ECU has no problem with that.
Trust me, I want it to be true as much as anyone.
Old 03-28-2011, 01:30 AM   #17
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Did you have to re do the clearances with new buckets and shims?
rob323 is offline   Reply With Quote
Old 03-28-2011, 01:42 PM   #18
Dylan Yap
Drives: Toyota Vios
Dont need, as this are bolt-on Cams. Just plug & play
JUN Releases Camshafts for the 1NZ-FE changchewsoon Performance Modifications 53 01-23-2017 08:28 PM
JUN Auto Releases High Lift Camshafts for Toyota 1NZ-FE changchewsoon Performance Modifications 7 02-16-2011 03:46 PM
Gude cams "NOT SO NACHO" xbgod Performance Modifications 77 01-27-2011 01:45 PM
JUN Auto - 1NZ-FE I-Beam Connecting Rods changchewsoon Forced Induction Forum 10 04-19-2010 11:00 AM
GI: Custom Cams lilredrocket Performance Modifications 62 11-13-2009 10:10 AM
