Old 08-19-2011, 11:31 PM   #19
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
are you running an underdrive pulley?
Old 08-20-2011, 07:12 AM   #20
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
No
The Spectacle is offline   Reply With Quote
Old 08-20-2011, 09:48 AM   #21
mo_feezy
Drives: 08 Yaris S Sedan AT Black
I have a less than 6 month old battery in mine. I checked yesterday. I was getting 13.7 with everything off (while driving), 13.6 with AC running, and then fluctuating between 13.5 and 13.6 with the AC and the system (about 600 watts or so). Idle voltages are similar, never dropping below 13.3 and never getting higher than 13.7 really.
mo_feezy is offline   Reply With Quote
Old 08-27-2011, 12:33 AM   #22
MGargano
Drives: 2009 Yaris Hatchback
I've been having the exact same issues/voltage readings as The Spectacle.
I did the Big 3 upgrade and saw no change. I swapped the alternator, no change. I disconnected all extras (HIDs, sound system, radar detector, etc), no change. I even went so far as to have NST custom build me a 20% overdrive alternator pulley for $150, but I ended up not putting it on and just living with the low voltage
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
possible alternator (voltage regulator) issue jesse1000 Canada 3 03-09-2009 09:10 PM
High voltage -m- DIY / Maintenance / Service 7 08-01-2007 09:48 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
