Old 11-06-2010, 01:13 PM   #37
Zebra
Zebra's Avatar
Drives: Yaris HB
I did some checking around Northern Minnesota but couldn't come close to the price Yaristeve mentions. So I took the plunge and ordered mine from the eBay seller. Should arrive next week and I'm looking forward to the change. The caps were easy, my dealer had a set on hand for $12.
Now to mount the TPMS and tires.
Zebra is offline   Reply With Quote
Old 11-12-2010, 12:03 PM   #38
Zebra
Zebra's Avatar
Drives: Yaris HB
My spoke rims showed up on Wednesday and I had them mounted on Thursday. Local tire dealer Pull the tires off the steelies and moved the TPMS sensors to the alloy wheels. $50 for the job and had it done in 35 minutes. My Toyota caps haven't shown up yet so I just put on the Scion caps for now.
I'm happy!
Old 11-12-2010, 02:43 PM   #39
kimona
kimona's Avatar
Drives: 2014 White VITZ
They look great! $50 was very reasonable for the swap.
Old 11-12-2010, 04:52 PM   #40
Zebra
Zebra's Avatar
Drives: Yaris HB
I agree! They whipped through it in record time and even wiped everything off before putting the car down off the lift. (very professional) My dealer quoted me $165 to do the swap so I told them I'd pass. (it's a Yaris, not an Avalon!)
Being too impatient to wait for the Toyota centercaps, I installed the Scion ones that came with the wheels. Thought I could just pop them off with the new ones arrived but that was a bit optimistic, they won't budge and the Toyota version arrived today. Guess they'll have to stay on for the winter cause I'm not taking the wheels off to change them!
Old 11-12-2010, 05:01 PM   #41
Zebra
Zebra's Avatar
Drives: Yaris HB
Hey! I just wanted to send my 'thanks' to AUXMIKE for the link to these rims on eBay too! You helped me find a great set of rims for a reasonable price. Thank you!
Old 09-15-2011, 03:49 PM   #42
henrylee
henrylee's Avatar
Drives: 2011 Yaris Sedan Red Power pkg
Originally Posted by jpmck03 View Post
Arrived today while I was at work. Installed when I got back.
Of course it started to rain once I was done putting them on.
Look great, and the price was right. Now to get those Toyota center caps to replace those Scion ones...
Better pics to come once it's light out and it's not raining...
My toyota center caps came in. But Im guessing the wheels have to come off to remove the scion center caps? CRAP!
henrylee is offline   Reply With Quote
Old 09-15-2011, 06:33 PM   #43
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
I couldn't come up with a better plan at the time and just took each wheel off, then popped the center caps out from the back.
I'm sure that if wanted to try a more destructive method you could get the Scion caps off, albeit in pieces instead of whole.
Old 09-17-2011, 02:02 AM   #44
EPyarisdriver
...or Vegas for short
EPyarisdriver's Avatar
Drives: 2010 Toyota Yaris 3door LB
Looks good!!
Now just drop her and shell be sexy..ER!
EPyarisdriver is offline   Reply With Quote
Old 09-19-2011, 11:41 AM   #45
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
my old '06 xB had these wheels & i loved them...now that I see them on Yaris' i might have to get them
they would look sexy on a white car
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-29-2011, 07:45 PM   #46
wolfywho
wolfywho's Avatar
Drives: 2011 3-Door Liftback
Originally Posted by auxmike View Post
Fit is snug and the setup was reasonable @ $608 delivered UPS for 4 mounted/balanced tires on the 4 rims ready to install right out of the box.
When you say the fit was snug, what do you mean exactly? Has anyone had problems with tires rubbing, since these are 6" wide wheels? Is anyone running these with the TRD suspension and coil upgrade?
Do these have the same offset as our 15" steelies?
The wheels look nice, and the price certainly is hard to beat. Thanks!
-Wolfy
wolfywho is offline   Reply With Quote
Old 09-29-2011, 10:45 PM   #47
auxmike
auxmike's Avatar
Wolfy,
I meant to say they fit snug on the hub and don't wobbel around. Some aftermarket rims require centering rings that sit inside the center hole of the rims properly. These are a perfect, secure fit. No rubbing at all to report after a year. I'm running stock sized tires too.The finish looks great still and I only clean them with soap and water, no chemicals.Don't be spooked by the 6 inch width, it's trivial and these are designed by Toyota for a proper, safe fitment to the car.
Old 09-29-2011, 11:34 PM   #48
Viperoni
Drives: 2005 Toyota Echo
Wolfy,
6" pinches a 205/50 or 205/55 tire, it's much happier on a 6.5" rim.
They do look good on the car though... too bad they don't come in a 16x6.5!
2006 Saturn Ion Redline
Old 09-30-2011, 12:11 AM   #49
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Wolfy,
Oh, they are definitely snug. Particularly when they were stuck to the hub...
Not that that's the wheels' fault. Chalk it up to lovely northeastern weather. Some grease will be applied next spring when I put them back on...
But like auxmike said, they're great!
Old 09-30-2011, 08:03 AM   #50
wolfywho
wolfywho's Avatar
Excellent. Thanks for your replies everyone. It's very helpful. I'm seriously considering these wheels.
Old 09-30-2011, 10:52 AM   #51
kimona
kimona's Avatar
205mm tyres can fit quite "happily" on 5.5-7.5" rims.
Old 09-30-2011, 11:18 AM   #52
wolfywho
wolfywho's Avatar
I was thinking of going a little wider than the stock size of 185 on the tires. Maybe 195 or 205. How much of a loss in gas mileage will I see with a wider tire? Will the ride comfort be better with a wider tire? Also, how wide could you go before interferring with a TRD shock/strut/spring upgrade?
Old 09-30-2011, 12:26 PM   #53
wolfywho
wolfywho's Avatar
Anyone know the weight of these wheels, compared to our steelies?
FS: Yaris RS Alloy wheels W/Tires & Lugs mr.white_hb Items for Sale by private party 23 03-30-2009 10:40 PM
2006 Scion Xa steel wheels... Chupacabra Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-07-2008 06:52 PM
