Old 11-21-2011, 08:41 PM   #1
vrwm
vrwm's Avatar
Drives: 2012 Super White Yaris SE
DIY: 2012 Radio Removal
Tools Needed:
1.Kung Fu Grip
2.8mm Socket, Extension, and Ratchet(I Used 8mm Screw Driver)
or Philips #2 Screw driver
Step 1.
Starting on the right side of vehicle(Passenger side USDM) pull the surround panel using your kung fu grip by the a/c vent. It is held in by clips all the way around. After you loosen the first clip just pull gently all the way around.
Step 2.
Pull the surround out around the radio. Held in by clips similar to the dash panel.
Step 3. (Optional)
Remove the connector for Hazard Switch. (I left it connected and let it hang)
Step 4.
Unscrew the Radio using your tool of choice.(Yellow dots, 2 screws on each side)
Step 5.
Pull the radio out and remove connectors.
vrwm is offline   Reply With Quote
Old 11-21-2011, 10:44 PM   #2
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
very nice. what are you going to put in instead?
mr9865 is offline   Reply With Quote
Old 11-22-2011, 01:59 AM   #3
vrwm
vrwm's Avatar
The stock radio actually has everything I need, Ipod integration, Bluetooth Phone and Audio(I can even stream Pandora and watch youtube and it will play through the car speakers with the display of the text of whats playing.) I can use a USB Thumb drive, or just a regular aux port. It has HD Radio(You have to let it switch to HD mode and then there will be a 1/2 or a 2/2 in the top right corner to switch stations. It took me a while to figure that out.) I was actually tapping the wires for a subwoofer out. The only reason I would switch out the factory headunit would be for a Navigation display. I'm waiting for the Prius C to come out and see if that radio would be compatible.
Old 11-22-2011, 03:10 AM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Originally Posted by vrwm View Post
Tools Needed:
1.Kung Fu Grip
Can I pick one of those up at the Walmart?
Old 12-03-2011, 02:49 PM   #5
Strider199
Strider199's Avatar
Drives: Black 2012 Yaris 3door 5speed
No but if you still have access to a G.I. Joe, you'll be good.
New to the Toyota World, be nice.
Strider199 is offline   Reply With Quote
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 305 10-27-2025 01:52 PM
DIY amp wire running and radio trim removal Slick In Car Entertainment + Electronics (audio / video / alarm) 29 12-20-2021 08:58 AM
DIY: 2012 Front Bumper Removal vrwm Third Gen Yaris General Discussion 15 07-19-2013 05:23 AM
DIY amp wire running and radio trim removal Slick DIY / Maintenance / Service 0 09-10-2009 08:00 PM
