![]() Drives: 2007 YRX Hatch Join Date: Sep 2011
Problems Mounting Tweeters
Hi all,
I recently purchased some Alpine Type G components for my Hatchback, and i'm struggling to figure out how i'm going to mount them. I've seen lots of pics on this and other forums where people have mounted them in the door handle like this: ![]() I assumed this would be the easiest course of action, as everything I've seen basically states that you just need to drill a hole in that one piece of trim. I have zero experience with car audio, but this seemed like the best option, as it also meant all the wiring was contained to the door, and I didn't have to mess around with the A-pillar which has an airbag in it. So I went out to check that it really was going to be this simple, and this is what I came across. ![]() So this is the piece of trim where I intend to mount the tweeter, all good, so I take it off... ![]() ...and this is what's underneath. Now, if I were to try and mount a tweeter in this position, then I'm obviously going to have to drill through this section too. Nowhere in anything I've read have I seen any mention of this. I just assumed that there was empty space behind the top panel. How would I drill/cut a hole through this? Does it matter if I have to mangle and make some of the clip holes unusable? ![]() A picture of the tweeter in the position I'm intending to mount it. It looks like cutting through this section would be pretty difficult without a dremel. Any suggestions for alternative ways? The other option I guess is to mount it in the A-pillar, but I'm really not keen on that. Can anyone who has done this same install comment on how they managed to do this. Was cutting required? Am I missing something obvious? Thanks very much for you time.
2007 Tuscan Sunset/Copper Orange Mica Yaris YRX Hatchback. |
Hmmm I did an extensive search before I posted this, but only just now ran across this thread:
http://www.yarisworld.com/forums/showthread.php?t=28260 Shows what I want I think. Still curious on what would be the best tool to gouge out that section though.
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
I would use a 2" hole cutter with a drill and cut through the under panel.
#4 | |
I did this in mine and I would recommend removing the entire door panel. Leave the top cover piece on when you drill through. You should be fine with the clips. I even mounted mine further towards the front and it was fine. |
^ same here
Thanks all, I got around to it on the weekend. Ended up using a stanley knife to cut through the underpanel. It looks pretty good, only problem is my tweeters don't sit quite flush due to that panel being slightly curved. I don't know how to fix it, but it's good enough for now, until it bugs me enough to try and glue them down or something.
Roadrunner Jr.
Mmmm...that's the rub. You've got to know the surface you're mounting on. You COULD cut out a larger rectangle-ish area to make room for a flat baffle to mount the tweeters on. By then though, you might as well have put them in the a-pillars with all the work you're going to do to make it look nice.
A pillars are a better location anyway due to PLDs.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
Yep gotta say I chose this location cos of ease of installation, but having done it, i'm pretty certain the A pillars would have been easier.
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Sorry for bump.. but if you still have an issue with the gap you could find a rubber grommet/gasket and put it between the tweeter and the panel piece.
![]() Drives: 2008 YRS 5Dr LB (1.5L) Join Date: Dec 2011
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
lol... good times. I didn't have a drill at the time, so I used some old knives I didn't care about...heated the knife on the gas stove and melted a hole in the plastics. Had to disable the smoke alarm as it blasted off, but turned out good in the end.
Not quite a noob
How does the wiring for a tweeter work if I wanted to DIY? I've been looking into this for a bit now
| tweeters in door | centrysis | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 06-04-2010 11:01 AM |
| Best place to mount tweeters in the LB? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 01-18-2010 11:45 PM |
| Powering/Installing Tweeters? | eii | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-12-2010 09:00 PM |
| A-Pillar gauge pods that can fit tweeters? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 11-23-2008 02:25 PM |
| 6.5" Subs in rear? Mounting depth | Yucky Darren | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 04-19-2007 02:46 PM |
