Old 02-27-2012, 08:29 PM   #37
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
This one was a Kia Spectra hatch with ten vented 10" woofers...two altys and Tolm's favorite, a bank of batteries.
I get a headache just thinking about that. Amazing pressure. If they get much stronger they're going to need to be called sonic weapons.
Colin Chapman disciple
Old 02-28-2012, 12:15 AM   #38
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm telling you, sitting in it while it was playing...I almost lost my breath each time the bass line hit.
The two videos I have don't do the experience justice. We played around with...get this...modified Justin bieber, Celine dion, and some Toby Keith...we tweaked the bass in the tracks to be stupid loud. Imagine rolling up on someone, playing a totally girlie track and no matter what they tried, they couldn't out do you. It was a big middle finger to the "regular" thought of bass songs.
― Thomas Paine
Old 02-28-2012, 01:32 PM   #39
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Wouldn't you be able to take a DMM set it to VAC and connect it to you speaker outputs on your sub amp ? Then with that reading do the math on how many watts are comming out of the amp. Then from there calculate the current ? just wondering ?
Old 02-28-2012, 07:38 PM   #40
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Just out of curiosity, give it a try and let us know what your initial reading is and what part of Ohm's Law you use to convert...
I'm thinking that this is a great learning opportunity!
― Thomas Paine
Old 02-28-2012, 11:26 PM   #41
Viperoni
Drives: 2005 Toyota Echo
The truth of it all is that most of us are only drawing tons of current for very short intervals. I can tell you this much, on our stock alty, the only time I would get dimming was when I had a bass track in and was railing on the volume.
You're absolutely right. Even though I'm a basshead with the volume knob, I only get light dimming in the Echo. Sundown SAE-1200d running 3 Mach5Audio 12's.
When I had an Earthquake PHD3 in my old Saturn with an 80amp alternator, I had just a bit more dimming ;)
2006 Saturn Ion Redline
Old 03-02-2012, 01:41 AM   #42
_S7V7N_
_S7V7N_'s Avatar
This is a nice little calculator http://trussinme.com/Apps/audio/voltagecalc/default.asp
The math behind it http://forum.sounddomain.com/ubbthre...=1#Post1294233
Info courtesy of CA.com
I just finished my Big 3 today subs should be here this week, i'll post some numbers up sometime this next week, Maybe a vid !!!
dual, enclosure, inch, subwoofer, twelve
DIY - Daytime Running Lights ('07 Yaris Sedan) zuberio DIY / Maintenance / Service 0 03-11-2011 02:04 AM
Twin turbo dual exaust yaris 1NZ-FE setup? CtrlAltDefeat Forced Induction Forum 92 05-21-2009 01:14 PM
