that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
DRL mod idea
I've always thought that it'd be cool if there was a way to turn the DRLs on and off via some sort switch while the car is running. For the times when you want to be in "stealth mode" or like say if your in a drive-in (yes they ARE still around) and don't want to disturb anybody. I know most new cars that I've seen have some sort of switch, any ideas?
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
![]() Drives: 2007 Red 5dr RS Join Date: Mar 2012
This can be done easily by putting a switch on one of the DRL relay wires. I can't remember the specifics right now but I believe it's the blue wire. There's a thread on here on how to remove the DRL relay that should give you an idea of where to start. The wires are really short and tight near the relay though so it will be a pain to splice a switch to the wire.
#3 | |
| enable DRL at Yaris 2009-2011 | Ot_tO | DIY / Maintenance / Service | 6 | 06-15-2012 05:13 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| DRL to city/aux fog/LED | dean_park | DIY / Maintenance / Service | 9 | 09-13-2010 10:03 AM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
