Old 03-04-2010, 11:23 AM   #1
dean_park
Drives: 2011 VW Golf TDI
DRL to city/aux fog/LED
I like the idea of DRLs... but I really don't like the factory DRL in the Yaris.
What I've done in the past on my RSX-s is add a relay to the city light, so when the ON position is enabled, the city light in the high beam housing was enabled.
For my Element, I used the same relay, but added an 8W bayonet style bulb to the housing for the H4 bulb (city light add-on). It works OK, but a little dim.
The Yaris has the 10V going to the H4, but I'd really like to make it go to something else, like the small city light in the headlight housing or to a set of LED fogs. I wouldn't want the fogs to do anything else, but turn on when the DRLs normally do. Is there a wire that can be removed from near the headlight or DRL module and routed somewhere else? I assume there is a place where the 10V+ from the DRL ties into the regular 12V+ to go to the H4 bulb.
dean_park is offline   Reply With Quote
DRL in Yaris from...? Falconia General Yaris / Vitz Discussion 3 02-25-2010 02:22 AM
Disabled drl and installed hids and now no fogs... 604yarisrs Cosmetic Modifications (Exterior/Interior) 10 02-14-2010 01:26 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 07:37 PM
Where is my DRL Module......? Help With HID's The Architect DIY / Maintenance / Service 6 05-20-2009 11:21 AM
DRL disalbled. IllusionX DIY / Maintenance / Service 0 10-22-2008 04:16 PM
