Old 07-22-2012, 12:14 PM   #325
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by mazilla View Post
I get that, but I'd still put fuel rail in there somewhere so I didn't have to take all that stuff apart, maybe 5.5.
I'm not going to make any other changes while working on this manifold. They would only complicate the process which I want to be as simple and direct as possible.
It's really easy to get in way over your head by making multiple changes at the same time, so I'm going to completely avoid that situation simply by not doing it.
Old 07-22-2012, 12:42 PM   #326
tooter
play every day
tooter's Avatar
Originally Posted by Billiam View Post
1 million HP.
The 1 is a good guess.
Old 07-22-2012, 01:42 PM   #327
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by tooter View Post
It was perimeter clearances.
Aah, I hadn't measured any of the surrounding areas, just guessed at the perimeter measurements.
How are you doing on yours? I hope that sharing the details of the process will help to move your manifold along.
Mine is pretty much shelved until I'm ready to do engine management--I'm not interested in fighting the ECU--but that will allow me to do cable throttle and a custom intake/exhaust setup. Then again, if your project works out as a net gain, I may just press on ahead with it.
Old 07-22-2012, 02:17 PM   #328
Changing one thing at a time is a great strategy. There have been many times I wish I followed it, both on my cars and in my life.
Old 07-22-2012, 03:21 PM   #329
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
That is an OK strategy for "almost stock" type builds.
If you go "full race" type build you gotta jump in with both feet.
Old 07-22-2012, 03:37 PM   #330
tooter
play every day
tooter's Avatar
I also guessed and used a simple hand file to fit. On the bottom and the right, there are no perimeter issues. At the top just left of dead center, and the right side near the flange mounting stud are the two areas.
Cable control is a completely different road which I'm not willing to travel. However, I'm happy to be the first manifold "lab rat", and will let you in on all the details.
Old 07-22-2012, 04:39 PM   #331
But after you do that build, it's still better to change one thing at a time, when possible, or you'll never know what change made the difference, either way.
Old 07-23-2012, 01:45 AM   #332
tooter
play every day
tooter's Avatar
Here's a pic of a gasket fit during the CNC of the throttle body adaptor...
These guys are artists!
Old 07-23-2012, 10:18 AM   #333
I like it.
Old 07-23-2012, 10:22 AM   #334
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
so.....time to head to the welder?
Old 07-23-2012, 11:16 AM   #335
tooter
play every day
tooter's Avatar
No welder yet...
Today I go to the shop after work to return the flange that was hand filed to fit to the engine, so they can input the corrected dimension data and CNC another flange...
...then I go to the welder.
Old 07-23-2012, 12:01 PM   #336
vten
Project is looking good tooter !
Old 07-23-2012, 12:02 PM   #337
BEEF
BEEF's Avatar
so they are going to mill you out another flange? are you paying for every time you use them or is it one fee? you could just used the filed one.
sorry, being impatient. I like this little project. regrardless of the gains, it is going to look mighty mean on the front of that engine.
Old 07-23-2012, 12:28 PM   #338
tooter
play every day
tooter's Avatar
Originally Posted by BEEF View Post
...sorry, being impatient.
That's ok... as long as I'm patient the project will turn out just fine.
Old 07-23-2012, 07:06 PM   #339
tooter
play every day
tooter's Avatar
Here's the throttle body adapter...
The camera flash made the intake runners show up inside the manifold. I think this manifold has a distinct design advantage in that all 4 of intake ports of the runners are in direct line with the axis of the throttle body bore, like a backwards flowing exhaust header.
It turned out beautifully...
...and was quite a challenge for them to design a smooth transition from the 3 bolt manifold to the 4 stud throttle body without any of the 4 studs conflicting with the 3 hex bolts, while keeping the attitude of the rotationally sensitive gasket consistent with the throttle body's butterfly.
Old 07-23-2012, 07:10 PM   #340
That is a PRETTY piece of work. I would make an extra one to have on my desk.
Can I sleep with it before you install it?
Old 07-23-2012, 07:20 PM   #341
tooter
play every day
tooter's Avatar
Thanks, Garm... but I can't take any credit for it as I know absolutely nothing about the manufacturing process. I only laid out the basic idea and let the guys decide how to implement a design in the best manner they saw fit.
Old 07-23-2012, 07:31 PM   #342
vten
verry verry nice Tooter !! I think you should polished the whole thing from the manifold to the air intake ....industrial looks.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
