Old 07-23-2012, 08:59 PM   #343
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Not sure what to do just yet. I might just have it glass beaded to a low metallic luster. The old manifold is really convoluted and has a lot of surface imperfections in it, and would be a real challenge to polish.
Old 07-23-2012, 09:05 PM   #344
Jason@SportsCar
Have it ceramic coated. Moving from the plastic to aluminum intake has the potential to raise your intake temp, coating it would help keep all the hot air from the rad from cooking it.
Lots of finish options: http://www.jet-hot.com/
Old 07-23-2012, 11:42 PM   #345
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Can I sleep with it before you install it?
I just had the worst mental image... Thank you for that!
Old 07-24-2012, 08:41 AM   #346
Viperoni
Drives: 2005 Toyota Echo
Lookin good!
2006 Saturn Ion Redline
Old 07-24-2012, 11:46 AM   #347
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
not to sound mean...but damn the flanges make the rest of the manifold look like crap
THEY ARE SEXY!!!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-24-2012, 11:57 AM   #348
tooter
play every day
tooter's Avatar
THEY ARE SEXY!!!
I know... the machined parts are so stunningly beautiful it just makes the contrast to the old junkyard manifold look even worse. Glass beading should unify the surfaces. However, I may not glass bead the throttle body adaptor because it's so nice looking just the way it is.
Old 07-24-2012, 02:39 PM   #349
Can we get a new summary on the whp/torque pool?
thanks
Old 07-24-2012, 09:02 PM   #350
tooter
play every day
tooter's Avatar
Sure, Garm.
malibu +4 -6
Tooter +2 -3
Mazilla +1,000
Garm -5 -5
Anomaly +1 -3
Ljming -3 +3
BEEF +3 -2
Goldeenoh +5 -3
Goliath 0 0
tk-421 +4 -3
Billiam
+ 1,000,000
Old 07-24-2012, 09:50 PM   #351
malibuguy
Obsessed with 1.5L
Lol that cracked me up
-96 Tercel 4dr
Old 07-26-2012, 02:20 AM   #352
tooter
play every day
tooter's Avatar
Here's some pics of the new flange for the intake manifold...
The manifold needed a name... so I figured what the heck, I'll call it a tooter!
Since the CNC machine did not make undercuts, the port was scribed and I'll simply file it by hand down to the mark to fit. This completely resolved the port matching issue.
Old 07-26-2012, 07:09 AM   #353
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Those guys are doing great looking work! I'd hate to know what the reatil price of this project would be though. for making it happen.
Old 07-26-2012, 08:08 AM   #354
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
ok, wow....I really like the screen name milled into the top of it. that makes it really pop (not that it didn't before). this is going to look so good on your car.
Old 07-26-2012, 11:00 AM   #355
tooter
play every day
tooter's Avatar
I have absolutely no idea how all of this will shake out, because I still don't even know how well the manifold will work. The fun is in finding out.
Old 07-26-2012, 11:13 AM   #356
tooter
play every day
tooter's Avatar
The manifold needed a name so I just used "tooter".
The CNC machine is not set up to generate lettering fonts, so I designed the letters to be a simple mechanical combination of six evenly spaced circles and straight vertical and horizontal lines... and am totally pleased with the results.
Old 07-26-2012, 11:56 AM   #357
Manifold name looks cool, and certainly personalizes it.
I'm thinking that anybody who is not in the know is going to call it Jooter.
Old 07-26-2012, 12:00 PM   #358
"Jooter" is COOL.
Old 07-26-2012, 12:21 PM   #359
tooter
play every day
tooter's Avatar
Maybe that's a Canadian or European thing... but here, lower case j's extend below the writing line and are dotted and not crossed, and upper case J's are not fully crossed like T's are.
Either way is fine. It's catchy. Logos need to be catchy.
Old 07-26-2012, 04:22 PM   #360
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
looks like your "j" and "t" made a baby or you put the lower case "t" backwards :D
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
