#73 |
play every day
Hope it's cool that day!
![]() Try for first thing in the morning. My day ended up being be fairly hot at 88 degrees. |
#74 |
^ We'll be dyno-ing with and without the manifold during the same session (and possibly with the 1ZZ throttle body as well), so it won't matter what the temperature is in order to compare differences.
#75 |
how will you overcome the "learn" function for both dyno pulls?
Or will you simply reset the ecu before each pull? |
#76 |
^ At WOT it won't matter, there isn't any ECU "learning" in open loop.
It does learn your "style" etc. for regular driving/partial throttle/cruising; that's what we've been testing this week.
#77 |
oh ok :)
#78 |
![]() Drives: Yaris 1.3 07 Join Date: Oct 2011
looks great ;)
it is 2" inches isn't it ?? ... waiting for the dyno |
#79 |
Modded Moderator
#80 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Will this fit with the aFe intake? $$?
#81 |
^ We don't know the price yet, and we haven't tested it with any aftermarket intakes. What you see in the thread is everything we know and have done so far.
If the dyno shows some power gains, we will further refine the design if we can to fit the stock or aftermarket intakes to the manifold.
#82 |
![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
Those J Bend tubes are super sexy. sure beat the plastic composite look.
#83 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I'd buy it even if I had to modify the factory/aftermarket intake. Maybe include a intake with a diameter tube that matches the 1zz tb with a mount for the MAF sensor? Eagerly awaiting this to go up for sale.
#84 |
^ Good ideas. Dyno session is Thursday, after that we'll figure out what we're doing next.
#85 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
What is it with these intale manifolds all being dyno'd on thursdays???!!!
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#86 |
Because it's the best day.
#87 |
good luck Garm
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
#88 |
jqueza@microimage
Drives: 2010 vios Join Date: Apr 2012
ill be waiting for thursday results cant wait!!!
#89 |
Form>Function
2 DAYS!!!
#90 |
![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
I wonder if changing the intake manifold gasket to a non-metal material would help? More metal (compared to the plastic manifold) could translate to some heat soak?
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 01:06 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| Yaris Intake Manifold | richardholdener | Performance Modifications | 201 | 05-18-2009 11:58 AM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
