Old 09-06-2012, 11:05 PM   #109
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I guess ill start saving. Damnit how am i suppost to buy a house??!!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-06-2012, 11:40 PM   #110
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
SUCCESS. Didn't make much top end, but a nice midrange bump, right where you want it. Specs and dyno charts to be posted later. Couple of small improvements to be made in production.
I'm happy.
How much of a bump???
g.q.vios is offline   Reply With Quote
Old 09-07-2012, 12:38 AM   #111
Intake manifold notes and specs from today. As always, you can count on full disclosure and 100% information when we have something to show you.
I'm pretty happy with the results.
Our manifold made some nice power in the 3000-5000 rpm range, where most people will use it well. With some tuning, the top end will yield some power as well, AFR went pig rich at 5500+
ambient temperature was 90 degrees F
87 octane (91 would have helped us)
tested on a stock Yaris
Engine and bay were hotter for the pulls with MI manifold
Dyno Dynamics (tough dyno with numbers, 10-15% lower than DynoJet)
***some changes and improvements to be made in production
rich on top -- will deliver more power with some tuning
no CEL's
sounds badass
Here is the dyno chart (sorry for the large image). Grey is MI manifold, the other line is stock plastic mani. Chart shows power and torque comparisons.
here's a YouTube vid:
http://www.youtube.com/watch?v=IIMXX8bw8lE
Old 09-07-2012, 12:41 AM   #112
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Do you have the AFR graph as well?
Old 09-07-2012, 12:45 AM   #113
We did not have a chance to test it with the 1ZZ throttle body today, but that probably would have helped a bit more. Just a guess. Future dyno session for sure.
Old 09-07-2012, 12:45 AM   #114
bluevitz, yes, I'll post that next.
Old 09-07-2012, 12:48 AM   #115
Old 09-07-2012, 12:51 AM   #116
malibuguy
Obsessed with 1.5L
Im liking this.
1zz tb and tune damn skippy
-96 Tercel 4dr
Old 09-07-2012, 01:12 AM   #117
chaditotx
Drives: 2007 3dr hb 5sp
I wonder why the ecu decided to go so rich? I guess a tune will squeeze a bit more out.
chaditotx is offline   Reply With Quote
Old 09-07-2012, 01:34 AM   #118
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I can't wait to buy one and install it with a 1zz tb. Any plans to try it out on a yaris with some mild mods? Id love to see how this does on a car with i/h/e and a 1zz tb.
4/20 NEVER FORGET is offline   Reply With Quote
Old 09-07-2012, 01:36 AM   #119
^ I sure want to or with a Zage kit at low boost.
I think I'll throw one on my car with a 70mm TB and see what it pulls too. Let's see what 25 psi does to it.
Old 09-07-2012, 01:40 AM   #120
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Congratulations, Garm! It looks like a really nice fat torque curve.
In what gear did you run it? My runs took about three times as long as your dyno video! Also what intake did you run on the throttle body. It was difficult to make it out in the video.
Old 09-07-2012, 01:43 AM   #121
3rd gear pulls. Simota air filter (I think) on stock throttle body/MAF tube. (the rubber tube that feeds the stock airbox).
we tried pulls with and without air filter attached -- made no difference in power/torque at all.
Old 09-07-2012, 04:04 AM   #122
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
gonna blow the welds right off the mainfold.
-Derrick-
Old 09-07-2012, 09:10 AM   #123
malibuguy
Obsessed with 1.5L
Toyotas always seem to dump fuel on the top end. My tercel before the turbo would go to 10.3-10.5 range for the last 1200rpm...i called it Evo style...just blowing out black smoke.
Its also why i can get away with mild boost with no tuning...im still 11.6~ on the top end
-96 Tercel 4dr
Old 09-07-2012, 09:36 AM   #124
Yeah I observed that too on the 1NZ, perhaps it's a feature from Toyota engineers, prevent detonation in the worst possible conditions?
Old 09-07-2012, 10:48 AM   #125
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
My sentiments exactly, but I want one.
Old 09-07-2012, 12:13 PM   #126
tooter
play every day
tooter's Avatar
3rd gear pulls.
Can you help me out here, Garm? Because now I'm really confused.
3rd gear would have been cheating anyway.
1 to 1 is the most accurate, and the pull is long enough to record with precision -- in tooter's case, great precision.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 02:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 07:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 12:58 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-14-2008 12:26 AM
