#595 |
good to hear you found the problem
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
#596 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#597 | |
#598 |
#599 |
I looked at the pt mani and just didn't like having my turbo exposed to the open environment. It rains a lot here in Florida. I know Garm has manifolds too did u check with him? What turbo are you runnin now?
#600 |
Mr. 155 and climbing
Running MAP in the southeast, south, and southwest is much easier with it since its based off of a fuel curve that is programed into the ECU or Piggyback and it does not change. So basically, your fuel map never changes no matter what the air conditions are outside (dense, thin, wet, dry, etc). I don't know enough about MAP setups yet to do much more than sound dangerous, but going off what i have learned so far using your car for a racing application would easily justify going MAP since the car many times isn't a DD for most folks, but in this case it is his DD. He would need a 2 BAR Stainless Steel Sensor Kit which are over 100 bucks and then he would need to modify his piping or even replace a section so it is another investment for sure. IMHO if you are going to make the change and investment to go MAP then you are better off ditching the FIC to go full standalone since you are looking to optimize for higher boost and the FIC just doesn't protect your investment. It seems the FIC is for folks wanting to use low boost which traditionally won't put your engine in much for danger of blowing up compared to medium/high boost. 8-10psi is fun as it is on the roads so I would think that 15-18psi is more giggles for sure when at the wheel so being patient at that point rather than risk further time/money makes more sense. I am not sure what most would consider FI changing from a hobby build to serious is since it is subjective based upon the driver and the vehicle, but to me going over 15psi is getting serious.
#601 |
Not sure I understand what this is in reference to. He doesn't need a kit of any kind if he stays below~22psi. The FIC can handle that level just fine.
#602 |
Right, but you would be crazy to not have the Inlet Temp Sensor along with it. Sure, it has MAP built right in, but that is a static setting. You configure MAP instead of MAF, but MAP has no way to adjust for air density changes, in-climate weather, etc. The only way for the ability to have "on the fly" adjustment is with the Inlet Sensor being place too. Someone would be forever fiddling with the configurations throughout the year in northern states or Canada because of this. How is the FIC going to know inlet density/temps/humidity without an inlet sensor?
#603 | |
Maybe i am misunderstanding something. |
#604 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Ptuning.com |
#605 |
That's awesome to know! Do you get to keep your AC lines and would it fit in the Yaris bay. Really like your mani design.
#606 |
just awesome!!! what engine management do you normally uses ? piggy back ?
#607 |
If anyone is interested in the manifold e mail Andrew@ptuning.com
Ptuning.com |
#608 | |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
#609 |
C'est la vie
I recently had a huge loss in power while tuning at 19 psi of boost. I thought it was a clogged converter or muffler. Possibly a boost leak or BOV not closing. That was all wrong, it turns out I had a mass air flow sensor trouble code. I could not see it because my CEL is on all the time because my 02s sensors are disconnected. I cleared the code and the problem is fixed. Back to full power. I may need to adjust my MAF clamp voltage.
#610 |
Probably an out of range code and it went to default values.
#611 |
The ptuning maniold on their website does not look equal lenght ?
#612 |
C'est la vie
I think its about as close as you can get woth the space under the hood. I have seen one other but it required relocating the battery. And was over 2000$. I like the turbo above the valve cover. Looks cool and will make the exhaust much straighter and easier to fabricate.
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
