Old 08-28-2012, 12:08 PM   #577
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Did you use new bearings for your build?
Old 08-28-2012, 11:19 PM   #578
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
the higher a/r will easily add top end and help increase boost, you will lose spool, as in it will take a few more revs to spool the turbo.
id go with a .63.
Originally Posted by pimp my yaris View Post
Fuel pressure is set at 45psi at idle.
And yes I am increasing turbo boost because that is the whole point of getting enough fuel to support it.
I was beyond maxing the stock in tank fuel pressure regulator at 12psi
I am running into a new problem in trying to get to 15psi. It looks like my current .48AR turbine turbo will not flow enough air to maintain 15psi. I am getting to 16psi now, but as rpm,s go up boost is falling off. Time for a new turbo and a new manafold.
This is what Im liking
http://www.ptuning.com/html/Item-Des...9&ModelDesc=xB
Plus a tial external wastegate and a .64AR hot side turbo with a new custom 3 inch exhaust.
Old 08-28-2012, 11:33 PM   #579
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Yes, I bought toyota bearings. One of them came on a slow boat from japan. Could not find one in entire US. Also replaced the rear main seal and two O-rings between the block and upper oil pan. And U will need another two O-rings between the oil pump/front cover and block. Dont forget head gasket, valve cover gasket, intake and exhaust manafold gaskets.
pimp my yaris is offline   Reply With Quote
Old 08-28-2012, 11:37 PM   #580
pimp my yaris
C'est la vie
id go with a .63.
Yes thats the plan. And I definitly need the external wastegate. The internal gate does not move fast enough when cranking up the boost.
Old 08-29-2012, 12:33 AM   #581
That's closer to my set up -- you'll love it.
Old 09-07-2012, 07:57 AM   #582
pimp my yaris
C'est la vie
I am having trouble tuning for above 16psi with my FIC. I believe it is ignition problem. Above 16psi I am getting a nasty missfire between 3500 and 4500 where my boost is getting to 18-19 psi. Still working on it, I havent givin up yet. I will try to retard timing a little more at high boost to resolve this. Any tuners out there run into this? I noticed that tuning with the FIC is getting tough as boost climbs. My AFR's are fluctuating a lot within the same cell on my fuel map.
Old 09-07-2012, 08:00 AM   #583
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
has anyone else ever gone this far with an FIC? 16psi is starting to get pretty serious.
Or try some simple things like close the gap up a thou or two on the plugs
Old 09-07-2012, 10:07 AM   #584
pimp, what gap are you using, and which plugs?
Old 09-09-2012, 09:09 AM   #585
pimp my yaris
C'est la vie
I am running NGK BKR7E plugs gapped at .020"
Old 09-09-2012, 09:25 PM   #586
Bluevitz-rs
Have you tried a bigger gap? .020" is getting pretty small compared to the stock at what, 32 thou? It's possible the spark isn't big enough to ignite the mixture properly
Old 09-09-2012, 10:37 PM   #587
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
you got to stabilize you AFR. give it some more fuel make run 11.0-10.5 AFR then work your way back. you should not be misfiring like that if you have the proper fuel deleavery system in you car.
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 09-09-2012, 10:55 PM   #588
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
So Brian raises a good question at least from a curiosity standpoint...how many PSI of boost is the AEM FIC supposedly good for?
Old 09-09-2012, 10:58 PM   #589
Yoda
Yoda's Avatar
The on-board map sensor is good for ~22psi.
Old 09-09-2012, 11:31 PM   #590
fnkngrv
fnkngrv's Avatar
MAP or MAF?
Old 09-10-2012, 12:46 AM   #591
Bluevitz-rs
The AEM has a built in MAP sensor
Old 09-10-2012, 06:11 PM   #592
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Pimp...I thought you were standalone man its crazy a fic at that boost haha looks like it works pretty great for just a piggyback...
you make me double think about going standalone...
Interior:ALL red, black roof
Old 09-10-2012, 08:20 PM   #593
Yoda
Yoda's Avatar
Do not double think go standalone.
Old 09-10-2012, 08:28 PM   #594
pimp my yaris
C'est la vie
I made a mistake in thinking my AFR was fluctucation. It turns out the were fluctuating because of the missfire. When the missfire occurs the afr went rich because of unburned fuel in the exhaust. I made some progress and its running pretty good after retarding timing a bit farther. Its pulling hard on the highway WOW!! Also Im going to need a new boost guage. Also I seriously need a external wastegate setup. I need to organize a Turbo 5K walk for my car. Gotta raise funds.
I called Ptunning about the turbo manafold I was looking at, and they said they have none in stock and it would take at least a month to make one. I was a little dissapointed. I am holding off on the order for now and rethinking this.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
