#883 |
That looks a lot better than before. The only concern is that the sensor is now a lot closer to the filter. Hopefully that won't cause a CEL.
#884 | |
play every day
The aluminium tube is 2.25 inches and the filter is 3 inches. There's plenty of room to move it out farther. For all the crazy experiments I've tried, so far I've never gotten a CEL light.
#885 |
play every day
The silicone adaptor came today less than 36 hours after I had ordered it on ebay. That's speed of light shipping.
So now the intake is ready (plus one more clamp) to install on the throttle body tomorrow... ![]() ![]()
#886 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I'm excited to see how the manifold performs with a 1zz throttle body. Good work on keeping this project going!
Also, is that a Simota intake tube for Yaris or for another car? The tube diameter looks larger than the 1nz throttle body. I am using a k&n intake right now and the throttle tube size is nearly identical to the 1nz throttle body diameter, so I knew in the future when I swap to a 1zz throttle body I was going to have to get an intake with a larger diameter tube. I remember reading something on here something saying that you couldn't go over a certain intake diameter because it would cause the MAF to throw a cel. |
#887 | ||||
play every day
![]() Quote:
![]() ...but is 2.25 inches at the MAF sensor which is the same as the Weapon R intake I've been using... ![]() The Weapon R flares out to 2.5" in front of the MAF sensor while the Simota remans at 2.25" but then flares out to 3" to fit the air filter. Quote:
#888 |
play every day
Got the intake mounted and it fits fine...
![]() ![]() Next comes the test drive. (oooh, goody )edit: The engine runs great... and no CEL light. Last edited by tooter; 10-28-2012 at 05:32 PM. |
#889 |
I see, thanks for the explanation. That's weird that the intake flares out right before meeting the throttle body. On the K&N it does not flare out so it doesn't require a reduced coupler.
#890 |
play every day
I believe it was specifically manufactured that way so that just one MAF tube would be able to fit both the 1NZ and 1ZZ throttle bodies.
Pretty clever idea, actually.
#891 | |
play every day
#892 |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
My memory is probably quite bad, not sure if the original tubing is hugging the battery.
Any issues there? i see from the picture that the grey tubing is up against the battery. |
#893 |
play every day
The tubing touches the corner of the battery because the tooter manifold relocates the throttle body a couple of inches to the right. However, it doesn't cause any problems as there isn't enough pressure on the corner to kink the tubing.
#894 |
play every day
The first run of redesigned adaptors is done. The advantage of these are that just one part works for both the 48mm 1NZ FE throttle bodies and the larger 51mm 1ZZ FE throttle bodies...
![]() ![]() There was a clearance issue with one of the hex head bolts and the larger diameter throttle body gasket. The solution was to simply reduce the diameter of the head with a grinder... ![]() The larger 1ZZ FE gasket fits perfectly. Just finished bead blasting, and it's ready to install on a manifold. ![]()
#895 |
2ZR swap. DO IT! Ask how!
Again with the car pr0n! Looks great, too!
#896 |
Have you done a test fit yet to make sure the 1NZ TB seals properly on the car running?
#897 | |
play every day
The 3mm larger diameter O ring gasket means a perimeter radius difference of only 1.5mm larger all the way around which isn't a lot. ![]() The 1NZ FE throttle body base has a much larger flat area on it's base than that. I'll be running a new adaptor this coming week to confirm that everything works. |
#898 |
I'm very interested to see if this makes power with the 1zz throttle body, which it should.
Keep up the good work! |
#899 |
play every day
One tooter manifold with the redesigned adaptor adapter is now complete...
![]() ![]() ![]() ![]() ![]() ![]() ![]() Now just one 51mm bore adaptor plate fits both the 1NZ FE and 1ZZ FE throttle bodies. The tooter uses all of the stock Toyota head bolts, studs, and nuts, and the stock Toyota O ring manifold gasket. It uses a Toyota 1ZZ FE throttle body O ring gasket which works fine with the smaller 1NZ FE throttle body, and uses all of the stock throttle body studs, nuts, and bolt. The manifold flange is hand clearanced fit to the head perfectly and simply drops right in. Not too bad for a wrecked dirty 14 year old junkyard part. ![]() It requires the intake to be shortened because the throttle body is repositioned about 2 inches to your right as you're looking at the engine from the front of the car. Last edited by tooter; 11-13-2012 at 12:02 AM. |
#900 |
Looks great! When is dyno day?
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
