Old 09-21-2012, 05:40 PM   #865
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by baseballfan416 View Post
39 vs 36 = about a 7-8% gain (3 of 36 = 1/12th = 8.5%). That's pretty legitimate!
It would only take about $5,250 in gasoline purchases to pay for the cost of a tooter... without the shipping!
The reason I'm intrigued by this is because here we have a product that was essentially taken off of a 1.8liter corolla engine (correct me if I'm wrong). That engine, in it's time, was rated 30city 40 or 41hwy mpg? Combine the better "breathing" capacity with a lower displacement and I think this could be of particular interest to the hypermiling crowd.
The slightly improved mileage was an unexpected consequence. I was the most concerned with losing driveability at low rpms because the ~20% larger runners. But they are also slightly longer than stock which I think helps some. The tooter would likely work well under a forced induction situation...
You never really know what's going to happen whenever you adapt something to an unintended purpose. It's a total crapshoot.
I'm picking up the rest of the flanges on Tuesday, and then they're going to start on machining the adaptors.
Old 09-21-2012, 06:44 PM   #866
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Am i the first to have confirm to the purchase of one tooter :D?
Interior:ALL red, black roof
Old 09-21-2012, 07:30 PM   #867
tooter
play every day
tooter's Avatar
Yes... you're the first.
Old 09-25-2012, 08:36 PM   #868
tooter
play every day
tooter's Avatar
All of the tooter manifold flanges are done now so I can start putting them on the manifolds...
The manifolds are all in various stages of being cleaned. They all basically looked like that dark dirty one as they're 14 year old junkyard parts, many from crashed vehicles. They all have scratches and dings, but look pretty decent when they're all cleaned and blasted.
Old 09-26-2012, 05:41 AM   #869
ljming99
Drives: Yaris '06
Manifold'mania
ljming99 is offline   Reply With Quote
Old 10-06-2012, 02:44 PM   #870
tooter
play every day
tooter's Avatar
With the flanges done, the machining on the adaptors will be starting when I get these larger gaskets so that the adaptor design can be altered to fit them.
This Corolla gasket is larger then the Yaris one and allows for a 51mm bore. I decided to make just one adaptor which will fit either a 1NZ FE or a 1ZZ FE throttle body. This will allow for an easy upgrade without needing to change anything else.
Old 10-09-2012, 10:34 PM   #871
tooter
play every day
tooter's Avatar
The larger Corolla throttle body base gaskets arrived today...
This will be much simpler with just one part that fits both throttle bodies. Now the rest of the adaptors can be machined. Tooter two is with the welder and should be ready tomorrow. Then it goes to the bead blaster...
Old 10-10-2012, 10:47 PM   #872
tooter
play every day
tooter's Avatar
The throttlebody adaptors might be done by the end of next week, and tooter two is all welded up and made it into the blasting booth...
Old 10-18-2012, 12:45 AM   #873
tooter
play every day
tooter's Avatar
Looks like others have also been adapting manifolds. This is an adaptor to mount a 2zz manifold onto a 1zz engine...
The stock 2ZZ engine makes 180 horsepower.
Old 10-18-2012, 02:24 AM   #874
baseballfan416
Drives: 2017 L 3-door
wait... so is this your next venture? making a corolla xrs manifold fit the yaris? dooood!
baseballfan416 is offline   Reply With Quote
Old 10-18-2012, 11:09 AM   #875
tooter
play every day
tooter's Avatar
I doubt it...
I still don't have a completed 1ZZ manifold yet, as the newely revised adaptors are still in the process of being machined. So far all I have is the running prototype on our daily driver. It's interesting that others have been doing the same manifold adapting idea.
Old 10-21-2012, 08:32 PM   #876
tooter
play every day
tooter's Avatar
Finally... one completely finished manifold...
The bead blasting put a nice low luster finish on it and made the welds look a lot better by making all the surfaces take on the same evenly blasted texture. I even blasted the adaptor so that it now has a matte finish similar to the throttlebody...
Tooter #2 one now becomes the daily driver tooter because it had the worst dings in it. They're only cosmetic and are barely visible when looking low from the front, but it's still not fit for sale so I don't mind keeping it for our own use.
I'm still waiting on the adaptors which should be ready any day now. Tooter #3 is ready for the welder, and tooter #1 is going to the blaster.
Old 10-21-2012, 09:47 PM   #877
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Damn, that's sexy! It's like car pr0n...
Old 10-21-2012, 10:04 PM   #878
Viperoni
Drives: 2005 Toyota Echo
Looking good!
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 10-22-2012, 12:06 AM   #879
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
sexy!
b20vteg is offline   Reply With Quote
Old 10-26-2012, 05:11 PM   #880
tooter
play every day
tooter's Avatar
I bought a Simota intake from Buddy Fan (Thanks, Buddy ) shortened and bead blasted it to match the manifold. And am waiting on a silicone adaptor to finish it off...
Test fitting it into the throttlebody...
Old 10-26-2012, 07:03 PM   #881
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That looks a lot better than before. The only concern is that the sensor is now a lot closer to the filter. Hopefully that won't cause a CEL.
Old 10-26-2012, 07:59 PM   #882
tooter
play every day
tooter's Avatar
That's just a test fit. It'll be a couple of inches farther away from the MAF sensor when the silicone adaptor coupling is installed.
The aluminium tube is 2.25 inches and the filter is 3 inches. There's plenty of room to move it out farther.
For all the crazy experiments I've tried, so far I've never gotten a CEL light.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
