#865 | ||
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() Quote:
![]() You never really know what's going to happen whenever you adapt something to an unintended purpose. It's a total crapshoot. ![]() I'm picking up the rest of the flanges on Tuesday, and then they're going to start on machining the adaptors. Last edited by tooter; 09-21-2012 at 06:08 PM. |
#866 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
Am i the first to have confirm to the purchase of one tooter :D?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#867 |
play every day
Yes... you're the first.
#868 |
play every day
All of the tooter manifold flanges are done now so I can start putting them on the manifolds...
![]() ![]() The manifolds are all in various stages of being cleaned. They all basically looked like that dark dirty one as they're 14 year old junkyard parts, many from crashed vehicles. They all have scratches and dings, but look pretty decent when they're all cleaned and blasted.
#869 | |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
Manifold'mania
![]() Quote:
#870 |
play every day
With the flanges done, the machining on the adaptors will be starting when I get these larger gaskets so that the adaptor design can be altered to fit them.
![]() This Corolla gasket is larger then the Yaris one and allows for a 51mm bore. I decided to make just one adaptor which will fit either a 1NZ FE or a 1ZZ FE throttle body. This will allow for an easy upgrade without needing to change anything else. |
#871 |
play every day
The larger Corolla throttle body base gaskets arrived today...
![]() ![]() This will be much simpler with just one part that fits both throttle bodies. Now the rest of the adaptors can be machined. Tooter two is with the welder and should be ready tomorrow. Then it goes to the bead blaster...
#872 |
play every day
The throttlebody adaptors might be done by the end of next week, and tooter two is all welded up and made it into the blasting booth...
#873 |
play every day
Looks like others have also been adapting manifolds. This is an adaptor to mount a 2zz manifold onto a 1zz engine...
The stock 2ZZ engine makes 180 horsepower. |
#874 |
![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
wait... so is this your next venture? making a corolla xrs manifold fit the yaris? dooood!
#875 | |
play every day
![]() I still don't have a completed 1ZZ manifold yet, as the newely revised adaptors are still in the process of being machined. So far all I have is the running prototype on our daily driver. It's interesting that others have been doing the same manifold adapting idea. |
#876 |
play every day
Finally... one completely finished manifold...
![]() The bead blasting put a nice low luster finish on it and made the welds look a lot better by making all the surfaces take on the same evenly blasted texture. I even blasted the adaptor so that it now has a matte finish similar to the throttlebody... ![]() ![]() ![]() ![]() Tooter #2 one now becomes the daily driver tooter because it had the worst dings in it. They're only cosmetic and are barely visible when looking low from the front, but it's still not fit for sale so I don't mind keeping it for our own use. I'm still waiting on the adaptors which should be ready any day now. Tooter #3 is ready for the welder, and tooter #1 is going to the blaster.
#877 |
2ZR swap. DO IT! Ask how!
Damn, that's sexy! It's like car pr0n...
#878 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Looking good!
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#879 |
no show, no go :(
sexy!
#880 |
play every day
I bought a Simota intake from Buddy Fan (Thanks, Buddy
) shortened and bead blasted it to match the manifold. And am waiting on a silicone adaptor to finish it off...![]() Test fitting it into the throttlebody... ![]()
#881 |
That looks a lot better than before. The only concern is that the sensor is now a lot closer to the filter. Hopefully that won't cause a CEL.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#882 | |
play every day
The aluminium tube is 2.25 inches and the filter is 3 inches. There's plenty of room to move it out farther. For all the crazy experiments I've tried, so far I've never gotten a CEL light.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
