Old 01-22-2013, 12:59 PM   #19
Fenanorn
Drives: 2012 Yaris L 5-speed
I have a rattle in my 2012 dash as well. Sounds like it's drivers side and closer to the window...
Fenanorn is offline   Reply With Quote
Old 01-22-2013, 07:47 PM   #20
muffin_top
Drives: 2012 Yaris SE 5MT
I have a creak noise from silver radio bezel rubbing my dash kit, nothing some felt tape wouldn't cure.
Removing the soft touch dash trim is super easy and gives good access to the whole dash cavity. I looked around mine to see what could be rattling in others' Yarii and can't see any wires or panel intolerances. Very strange, mine is totally rattle free with TRD Sportivo suspension kit and almost 4k miles on her.. I'll look for any recent tsb's at work tomorrow.
muffin_top is offline   Reply With Quote
Old 05-25-2014, 01:57 PM   #21
Doix
Drives: '07 Yaris P9 Linea Sol 1.0
Exclamation Rattle at the right side of the dash too ...
KICK ....
Originally Posted by Frank Necrosis View Post
I have an annoying rattle the came from the right side of the dash. Turns out it was the cover of the USB port making the noise. Still trying to come up with a cure. The cover might be removed with a pair of scissors.
I too have a rattle at the right side of the dash. It's a 2007 Yaris. I do not know whether an USB port can be the cause? The problem is that the rattle itself sounds very 'plastic' and it seems to come from somewhere behind the glove compartment? When I am outside of the car I too hear the same noise, but a bit more 'iron'-like ... when checking underneath the bonnet I did not hear anything for about 10 minutes and nothing seems to be loose, worn or broken....? I am a bit confused now ....
Kind regards,
Aad ~ Doix
Doix is offline   Reply With Quote
Make dash less slippery to set coffee cup alpha1 General Yaris / Vitz Discussion 11 11-19-2012 10:39 PM
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 01:42 AM
2010 US 5 door stock exhaust, big rattle 127.0.0.1 DIY / Maintenance / Service 3 06-20-2010 09:39 AM
Dash rattle TSB needed ! tsportman DIY / Maintenance / Service 15 07-06-2009 06:20 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 08:39 PM
