Old 12-16-2012, 08:25 PM   #1
Dperry
Dperry's Avatar
Drives: 2007 black yaris hb
dash rattle?
does anybody have an anouying rattle from the top center of the dash... does anybody know what it is and a fix for the problem?
Dperry is offline   Reply With Quote
Old 12-16-2012, 08:47 PM   #2
matti
Drives: 2017 Yaris L (5sp manual)
I've got a rattle from both the left and right sides of the dash. Definitely interested in any ideas. I've tried to identify the source of the sounds, but not having much luck.
matti is offline   Reply With Quote
Old 12-16-2012, 09:42 PM   #3
yaris2010RS
yaris2010RS's Avatar
OMG! NOT THE 2012 TOOO!!!!!!
Old 12-16-2012, 09:42 PM   #4
I find that the cup holders rattle if they are left open, so closing them when not in use stops the rattle.
A rattle in the center could be from many things including: The cluster screws not being in place, the ducts to the center vents rattling, radio wiring not properly bloused (particularly if an after market one is installed).
Old 12-16-2012, 11:19 PM   #5
mr_miles
Drives: 2013 Yaris
They got rid of the awesome dash cup holders for the new gen :( Everything on mine rattles because of the coilovers lol.
Old 12-17-2012, 12:01 AM   #6
bebeelo
ThatYarisGuy
Drives: Toyota Yaris 2012 SE
i hear knocking noises on dash area when i steer to the left or right while im driving. idk what it is either
bebeelo is offline   Reply With Quote
Old 12-17-2012, 08:41 AM   #7
yaris2010RS
im sorry if im completely out of place here (i drive a 2010 not the fancy dancy 2012) but i fixed most of my dash rattles by putting pressure on it. i stuffed the bottom parts of my A pillars with sponge to compress the dash. worked quite well. i put enough to make it feel solid
Old 12-18-2012, 01:11 PM   #8
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
the top center of my dash used to rattle then just stoped... used to do it when hitting large bumps. mind you i had my 17's on then. and it wasnt bad.
Scubaru Steve is offline   Reply With Quote
Old 12-20-2012, 01:05 AM   #9
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
As soon as it got cold all the rattles came out. Everything rattles in the winter for me
mr9865 is offline   Reply With Quote
Old 12-20-2012, 07:11 PM   #10
Dperry
Dperry's Avatar
well i was watching a review on youtube and they got the dash rattle after about a week of driving. mine started about a month... when i put pressure on my dash were i think its comming from it stops.... i think theres a wire the just rattles agaist the dash. im kinda affraid to tear apart my dash to find out wut it is.
Old 12-26-2012, 12:21 PM   #11
Superfly
Makin' it rain
Superfly's Avatar
Drives: 2012 Silver Yaris LE
Man, that is no joke. As soon as it dips below 30 degrees, the whole car seems to rattle, especially the dash. Got to love the cold.
Superfly is offline   Reply With Quote
Old 12-31-2012, 05:34 PM   #12
yarisse54
Drives: 2013 Yaris SE
I think there was a post here on YarisWorld which explained how to remove the "soft touch" material to swap out the audio system. From what I recall, you simply grab the right side of the "soft touch" material and yank it towards yourself to pull it out. That should give you enough space to explore what wires are loose, and where you can add some triple expanding foam from Rona/Home Depot/Lowes.
This may not be the ultimate solution, but the 2012 Yaris could benefit from more sound insulation anyway!
yarisse54 is offline   Reply With Quote
Old 12-31-2012, 11:48 PM   #13
Scubaru Steve
Awesome!
-30 the suspension freezes and yes, the wonderful creeky rattles.
Old 01-01-2013, 01:40 PM   #14
bestyaris
Drives: Polar White 4 Dr
i too have this rattle. it gets worse during cold morning.
I am thinking to put some tape (black electrical) where dash & instrumental cluster meets
2007 Yaris Base Sedan
bestyaris is offline   Reply With Quote
Old 01-01-2013, 09:37 PM   #15
yaris2010RS
at -30*C you need to deal with a frozen clutch too....
Old 01-02-2013, 12:42 PM   #16
Frank Necrosis
Drives: 2012 Yaris L MT
I have an annoying rattle the came from the right side of the dash. Turns out it was the cover of the USB port making the noise. Still trying to come up with a cure. The cover might be removed with a pair of scissors.
Frank Necrosis is offline   Reply With Quote
Old 01-02-2013, 04:10 PM   #17
Superfly
Makin' it rain
Superfly's Avatar
I am going to have to check out the USB port cover. I know that the right hand side is where the loudest rattles come from but I don't know how such a small, soft cover could be making that much noise. Interested in finding out.
To the OP, it took me a few days but I noticed that the metal on the seat belts were bumping on the side pillars of the doors. If you can tuck them into the seam between the seat and frame tight enough that cures some of the more annoying rattles.
Old 01-02-2013, 10:34 PM   #18
Hershey
^ The '08 sedan seat belt buckle does same thing . Put some sticky back felt on it . Helps some .
Make dash less slippery to set coffee cup alpha1 General Yaris / Vitz Discussion 11 11-19-2012 10:39 PM
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 01:42 AM
2010 US 5 door stock exhaust, big rattle 127.0.0.1 DIY / Maintenance / Service 3 06-20-2010 09:39 AM
Dash rattle TSB needed ! tsportman DIY / Maintenance / Service 15 07-06-2009 06:20 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 08:39 PM
