Old 03-28-2013, 07:43 PM   #1135
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
rather phallic if you were to ask me...
I had to look that word up LMAO!
Old 03-29-2013, 01:19 AM   #1136
Old 03-29-2013, 02:00 AM   #1137
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Old 03-29-2013, 07:03 AM   #1138
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
The "Richard Cranium Special"
Old 03-29-2013, 07:25 AM   #1139
mr_miles
Drives: 2013 Yaris
I lol'd and now my coworker is looking at me funny
Old 03-29-2013, 11:51 AM   #1140
haha, nice. but I got us off-topic. Back to the tooter-penis-project-thing.
Old 03-29-2013, 12:08 PM   #1141
Bluevitz-rs
I just LOL!
Old 03-29-2013, 01:02 PM   #1142
tooter
play every day
tooter's Avatar
Yes.
I started doing a little preliminary grinding on one of the runner entrances not wanting to remove too much of the weld so as not to weaken the manifold...
And now that I'm going with the hemisphere, I can remove the rest of the square plenum. That will make it much easier to shape the runner entrances as it is impeding getting the Dremel at the proper angle.
Old 03-29-2013, 02:13 PM   #1143
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
LOL...Speaking of phallic symbols and alcohol...Hold up... need to shoot a pickleback...
JustDidIt is offline   Reply With Quote
Old 03-29-2013, 03:52 PM   #1144
jetblast
Drives: Gen 1 XB
Five things ya don't wanna hear when you open your hood.....
1) Hey big boy.
2) Is that your intake, or are ya just happy to see me?
3) Whip it! Whip it good, as the Devo music plays.
4) Shwing!
5) Damn, thought I at least had five......
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 03-29-2013, 08:18 PM   #1145
tooter
play every day
tooter's Avatar
Here's a comparison between the runners...
The welds do overhang the entrances quite a bit, so removing them should improve the flow.
Old 03-30-2013, 10:19 AM   #1146
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
That tooter looks great! Your experimental one looks like a jelly fish :p
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-30-2013, 04:18 PM   #1147
jetblast
Drives: Gen 1 XB
Better start making some porting templates. I would be interested to see what the physical diameter gains are. Looks like a nice improvement.
Old 03-30-2013, 05:08 PM   #1148
tooter
play every day
tooter's Avatar
Porting to the existing runner size increases the entrance diameter from 38mm to 40mm because the welds overhang a little more than 1mm all the way around. This nets a gain in the cross sectional area of just a little over 11%.
After all the overhanging welds have been removed, I'm going to smooth out and profile the entrances to more of a "bell" shape which should improve the flow even more.
Old 03-30-2013, 05:15 PM   #1149
tooter
play every day
tooter's Avatar
Sort of does. Maybe I should call it the "tooter squid"... although that name has negative connotations. It may end up earning the name squid after I get the dyno results!
Old 03-30-2013, 08:27 PM   #1150
tooter
play every day
tooter's Avatar
Cut the rest of the plenum off so that I could get the Dremel into the runner ports better...
Also gound off all the overhanging welds, and stainless steel bead blasted everything. This evens out all the grinding marks and will make it much easier to see the shapes of the ports while I'm grinding the bell mouths.
Before grinding...
...and after.
Old 03-30-2013, 08:32 PM   #1151
Bluevitz-rs
You going to smooth out the weld too?
Old 03-30-2013, 09:02 PM   #1152
tooter
play every day
tooter's Avatar
Yes. That's the next step. I'm going to form bell mouths for the runners, but I need to be careful not to take off too much weld because that's the only thing holding the runners onto the baseplate.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
