Old 09-15-2013, 06:41 AM   #19
willygoodness
Drives: 09 yaris hb
Originally Posted by D&D View Post
How are they working for me? Or where am I finding them to buy?
I need to learn how to ask questions better haha :/
how are you finding the ride quality of the springs compared to standard? And especially after you've cut 1/4 from top and bottom?
I'm looking at them on ebay and the only numbers on ebay page is
Spring Rate Front/Back: 170 lbs / 200 lbs
most other springs i've found have been front 5or6kg/mm and rear 3or4km/mm spring rate and I don't know how to compare those numbers
willygoodness is offline   Reply With Quote
Old 09-15-2013, 01:16 PM   #20
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Why?
Why? The car's too low in stock form.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 09-15-2013, 08:08 PM   #21
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
To me, they are barely any stiffer than the stockers. Not really firm feeling or bouncy at all. I would definitely recommend these for street only, and would not want them on a track.
These were some of the softest lowering springs I could find in my price range, and that's what I wanted, since the harder the spring you need the stiffer the shock you need to keep it under control.
http://www.onlineconversion.com/foru...1110951659.htm
You're kidding, right??
D&D is offline   Reply With Quote
Old 09-16-2013, 05:33 AM   #22
willygoodness
Drives: 09 yaris hb
Thanks D&D!! (Y)
Why?!?? haha
Old 09-16-2013, 11:25 AM   #23
Old 09-16-2013, 11:49 AM   #24
D&D
It's Quacktastic!
D&D's Avatar
Old 09-16-2013, 12:12 PM   #25
jcboy
Drives: Sedan 07
I'm pretty sure he is. Here where I live we even call it "Innova fender gap." (Innova is an MPV/AUV)
Old 10-31-2013, 06:38 PM   #26
jRoss
Drives: 2010 5spd sedan
I think noobs should know to cover the sharp part of the fender with something to avoid slicing their hands open
jRoss is offline   Reply With Quote
Old 11-02-2013, 12:08 PM   #27
aznssaiyan
Drives: 08 HB
did you cut your bumpstops? ill post pics of mine here when i finish my install.
aznssaiyan is offline   Reply With Quote
Old 11-04-2013, 06:38 AM   #28
willygoodness
Drives: 09 yaris hb
na. i didn't see a reason to cut bump stops.
they are rather nice ride. went 2 weeks then got a whiteline sway bar
definitely recommend a rear sway bar.
springs strut front m2
Lowered Springs - Toe, camber, caster alignment (Which ones)? Henry_mak16 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-22-2013 01:33 PM
my 2012 yaris lowered on trd springs dailygrindin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 05-04-2013 10:08 PM
Just got my Yaris YRX Lowered on King Springs! theconspiracymarket Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-03-2010 11:26 PM
lowered it DF210 springs mikenacarato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 11-27-2008 10:22 PM
NEED A PLACE TO GO GET MY SPRINGS INSTALLED IN NORTH NEW JERSEY smokinyaris NY / NJ/ CT / PA 23 06-26-2007 11:25 PM
