Old 09-15-2013, 08:08 PM   #21
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
Originally Posted by willygoodness View Post
I need to learn how to ask questions better haha :/
how are you finding the ride quality of the springs compared to standard? And especially after you've cut 1/4 from top and bottom?
I'm looking at them on ebay and the only numbers on ebay page is
Spring Rate Front/Back: 170 lbs / 200 lbs
most other springs i've found have been front 5or6kg/mm and rear 3or4km/mm spring rate and I don't know how to compare those numbers
To me, they are barely any stiffer than the stockers. Not really firm feeling or bouncy at all. I would definitely recommend these for street only, and would not want them on a track.
These were some of the softest lowering springs I could find in my price range, and that's what I wanted, since the harder the spring you need the stiffer the shock you need to keep it under control.
http://www.onlineconversion.com/foru...1110951659.htm
Originally Posted by Sir A.Y. Atoyot View Post
Why? The car's too low in stock form.
You're kidding, right??
D&D is offline   Reply With Quote
Tags
springs strut front m2
Lowered Springs - Toe, camber, caster alignment (Which ones)? Henry_mak16 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-22-2013 01:33 PM
my 2012 yaris lowered on trd springs dailygrindin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 05-04-2013 10:08 PM
Just got my Yaris YRX Lowered on King Springs! theconspiracymarket Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-03-2010 11:26 PM
lowered it DF210 springs mikenacarato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 11-27-2008 10:22 PM
NEED A PLACE TO GO GET MY SPRINGS INSTALLED IN NORTH NEW JERSEY smokinyaris NY / NJ/ CT / PA 23 06-26-2007 11:25 PM
