Old 11-12-2013, 02:49 PM   #1
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
Front caliper brake measurements
Trying to find out some specs for the front brakes
Stock rotor size (thickness and diameter).
Stock caliper mounting hole width and hole diameter.
Trying to explore some cost effective brake upgrades for us.
Old 11-12-2013, 04:36 PM   #2
Define upgrade?
Old 11-12-2013, 05:38 PM   #3
wildmongoose26
Exploring some stuff with a brake company. 4 and 6 pot, 12" rotors. Just trying to compare our mounting stuff to theirs
Old 11-12-2013, 05:43 PM   #4
You'd have to make either a bracket extension for the stock caliper to mate with a larger rotor, or a get a new caliper to mount a larger rotor. Which brake company?
Old 11-16-2013, 03:56 PM   #5
wildmongoose26
Looking for the mounting hole distance from bolt to bolt. There is a magic number were looking at and I'm hoping to find it. Anyone have a set of calipers off the car?
Old 11-16-2013, 09:42 PM   #6
The caliper frame mounts are exactly 140 mm O.C.
Old 11-16-2013, 10:09 PM   #7
^ Yep, that's it. Which brake company?
Old 11-16-2013, 11:26 PM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
the unpainted one is the stock yaris one.
Old 11-17-2013, 07:58 PM   #9
wildmongoose26
CTScott. Is this 140mm to center of hole, to outside edge, or inside edge of bolt hole?
Old 11-17-2013, 08:09 PM   #10
^ O.C. means 'on center', so it is 140 from center of hole to center of hole.
Old 11-17-2013, 08:18 PM   #11
wildmongoose26
Ahhh ok. Then we may have a winner. Gonna see about them sending me the relocation bracket to see how it lines up. If all goes well I'l have a BBK in the next month at a rough cost of $650, 12" rotor 4 pot caliper.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
FL-BNIB OEM toyota front brake pads gray09S-hatch Items for Sale by private party 7 04-19-2012 01:17 PM
Front brake clunk after reversing JonS DIY / Maintenance / Service 6 03-21-2012 12:02 PM
new brake pads up front yaris9876 Performance Modifications 3 10-06-2011 08:19 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 08:16 PM
