Old 02-06-2014, 10:55 PM   #1
regal
Drives: 09 Yaris 3 Dr White LB
Hit door
I saw a Yaris the owners were considering selling. The driver hit black ice at a low speef spin, hit a guard rail, it punctured the door and the skin and the glass. The door opens and closes just fine.
Looks like a simple replacement door to me/paint job to me, the milage is low and meticulously maintained by a couple in their 40s.
I've seen it in the neighborhood since they bought it, unfortunately they had paid it off and didn't keep comphehensive insurance. Its a '08 coupe with 40k miles.
Are there any gotcha'has here? Seems pretty low risk for a pretty risk for a door change, Even if it went as far as a new door fame (the hit is about 8" above the bottom of the door), I can't help but wonder what the worst case scenario would be.
The current owner was told eventually it would be be totaled if it had comprehensive so they just want to get rid of it. ?
I reallly find it hard to imagine frame damage. Isn't there some sort of "new" door adjustment on these?
Thoughts? Everbody needs 2 Yaris's.
Thoughts?
regal is offline   Reply With Quote
Old 02-06-2014, 11:17 PM   #2
bairjo
Regardless of the risk in buying it, you could buy it and always throw a snow plow on it...CTScott can provide detals on that!
bairjo is offline   Reply With Quote
Old 02-06-2014, 11:21 PM   #3
regal
No risk of the door frame splitting in two whlte plowig?
Old 02-06-2014, 11:24 PM   #4
If the door opens and closes OK, then it may just be the door. There is some play in the mounting holes for the door, so you can fairly easily make the adjustment when mounting the replacement. I have a good white door on hand, if you buy the car.
Old 02-06-2014, 11:30 PM   #5
regal
My worry is a hairline crack in the unibody from that propagates, splits and totals, the car, I guess that sounds far fetched now that I ink of it.
Old 02-06-2014, 11:35 PM   #6
The subframe is made with multiple thin layers of steel, so a dent is far more likely than a crack.
Name:  A Pillar cut.jpg
Old 02-06-2014, 11:39 PM   #7
Type456
Drives: Like the Yaris
Thoughts?
Damn, the way you phrased that, makes me feel old (since I am part of a couple in their 40's).
If it's just the door, its probably ok, but there are so many stresses on a car in a collision, you should have it checked out.
Type456 is offline   Reply With Quote
Old 02-07-2014, 08:04 AM   #8
regal
Not much experience with modern unibody,
Attachment 52811
Body shops can fix dents like this right?
I am used to the old adage unibody bent, crush it. I had a 84 civic with a similar bent door and I just swapped it out, didn'tven think of unibody damage, drove it 50k more miles.
I tempted to believe the local body shop guy just wants the car so he can yurn a healthly profit on it.
I guess I should have it checked out but the spot is so localized, more like a punxture that anything, he said he drove it straight hame and again the door open/shuts easily. He does want $2k.
Old 02-07-2014, 08:52 AM   #9
Not much experience with modern unibody, Body shops can fix dents like this right?
The fact that the door closes fine indicates that the door frame is intact, so I personally would not worry. The laminated metal construction makes cars much more flexible (as opposed to rigid members that crack), but more difficult to repair. If the door frame (i.e. A or B pillars) was visibly damaged or the rocker panel, then I would be concerned.
Old 02-07-2014, 10:28 AM   #10
regal
the rocker is twisted a little, can a frame straightening shop straighten it up?
Old 02-07-2014, 10:42 AM   #11
regal
This is what scares me, can a frame shop straighten something like this I? Its amazing the amount of damage a little hit can cause
http://i299.photobucket.com/albums/m...ps27f1e7d0.jpg
Old 02-07-2014, 11:06 AM   #12
This is what scares me, can a frame shope straighten something like this I? Its amazing the amount of damage a little hit can cause
That's a tough one. There is no place externally to really grab that and tweak it back into shape. What does it look like from the side with the door closed?
Old 02-08-2014, 12:04 PM   #13
regal
Checked it out under the sunlight. The "cracks" were just the white paint, there is a good sized dent under the pain but the fact that the door opens/closes cripsly tells so I took a chance and bought it.
I hate to scrap a 2009 with 50k miles and at least another 300k miles to go. As CTScott mentioned the toughest pat is going to finging a place to grap to pull he dent.
Where I live I know there are going to be a lot of local vulture's to fend off (Hey its tototaled : here's $200), but I am more optimistic than I was after the ice storm. Unfortunately I am not a unibody expert and a bit at the vultures mercy, however I've always gotten good advice here.
Old 02-08-2014, 12:49 PM   #14
regal
This is the photo from outside the rocker as CTScott requested.
http://i299.photobucket.com/albums/m...ps462508a6.jpg
I can't get ahold of an on probably because it is a Saturday and the weekend after the worst storm since Sandy (for our area.)
I am in no hurry so any advice is appreciated.
Old 02-08-2014, 01:46 PM   #15
From the pic the rocker panel doesn't look bad. I would probably live with it as is.
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 02:24 AM
The wind blows the Yaris door Jabberwocky General Yaris / Vitz Discussion 49 04-02-2014 11:40 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
Hit and run, need to replace door, help! neelieflower DIY / Maintenance / Service 4 03-10-2011 12:52 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 06:55 PM
