Old 02-07-2014, 07:52 AM   #9
Originally Posted by regal View Post
Not much experience with modern unibody, Body shops can fix dents like this right?
I am used to the old adage unibody bent, crush it. I had a 84 civic with a similar bent door and I just swapped it out, didn'tven think of unibody damage, drove it 50k more miles.
I tempted to believe the local body shop guy just wants the car so he can yurn a healthly profit on it.
I guess I should have it checked out but the spot is so localized, more like a punxture that anything, he said he drove it straight hame and again the door open/shuts easily. He does want $2k.
The fact that the door closes fine indicates that the door frame is intact, so I personally would not worry. The laminated metal construction makes cars much more flexible (as opposed to rigid members that crack), but more difficult to repair. If the door frame (i.e. A or B pillars) was visibly damaged or the rocker panel, then I would be concerned.
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
The wind blows the Yaris door Jabberwocky General Yaris / Vitz Discussion 49 04-02-2014 10:40 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Hit and run, need to replace door, help! neelieflower DIY / Maintenance / Service 4 03-09-2011 11:52 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
