Old 07-18-2014, 05:53 PM   #55
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Originally Posted by CrankyOldMan View Post
Yes, that's the right idea. I think you may need to count the Yaris again though, it should be 67:18 = 3.722. By "taller" do you mean the thickness of the gear, or taller/shorter gear ratio?
Taller is that the ring gear side by side the XD is taller than the Yaris ring gear
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 07-18-2014, 06:32 PM   #56
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Oh, yes, I noticed that too. If you just put the diff and pinion shaft in, they will scrape against each other. If you install the center housing and put the retaining clip on the bearing, it lifts the pinion shaft up a few mm, which should give plenty of clearance.
Old 07-18-2014, 11:34 PM   #57
Jerkratt
Jerkratt's Avatar
So going for track use... Swapping XD final drive out of the first Gen would be the way too go?
"It hurts more when its wet"
Old 08-11-2014, 09:41 PM   #58
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
I was looking in to parts for my XD tranny 2 & 3rd syncros, and notice the the 3rd gear is the same for most toyotas with C5X, 2nd gear is for the XD and 09+ corollas and the 1st gear is unique to the XD. What can be the difference in them?
R-CaT
Project Yar 2ZR
Old 08-12-2014, 08:51 PM   #59
CrankyOldMan
I'm not sure I understand what you're asking for. The difference in gear ratios, the difference between part numbers for identical rations, or something else?
Old 09-10-2014, 10:19 PM   #60
Jason@SportsCar
The XD output shaft and ring gear are different to the Yaris, they are larger you can"t drop a Yaris diff into XD tranny also one thing to look at is that the XD output shaft bearing is wider its the one that is next to the DIff so I don"t know if it cahnges the case or if it's just a different bearing.
With the xD FD not really being an option due to bearing/shaft size, and I want to use my OS Giken LSD, I wonder if the 3.9 FD from the C150 in the Paseo would be a better option? I think that might only be a 6 bolt. How about the 4.0 from a C52?
Old 09-11-2014, 07:20 AM   #61
CrankyOldMan
I would stay away from the C15x series, since they're 6-bolt. Unfortunately, my research hasn't turned up anything in the C5x series with a ratio other than those on the Yaris and xB, but I've also never torn down a C52.
The output/pinion shaft bearing has the same OD, it's just a different ID. Easy to swap with a blind bearing puller. As far as overall dimensions go, the Matrix and Celica differentials seemed to fit just fine--the axial length between the taper bearings looks to be identical.
Old 09-11-2014, 02:30 PM   #62
Jason@SportsCar
Have you evaluated any of the S series boxes, like the S53 from the Celica?
Old 09-11-2014, 02:57 PM   #63
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Jason you might want to look for the TRD 41201-NP100 final drive.
I believe the older AW11 MR2 and Celicas with the 4A-Fe engines used that final drive(4.058). Its a C52 so I'd imagine it would work.
Old 09-11-2014, 03:06 PM   #64
Jason@SportsCar
The TRD set has been listed as discontinued for years... Certainly its possible there is one out there, but good luck tracking it down.
Old 11-03-2014, 04:24 PM   #65
froger
Drives: 08 yaris 1.8 dual vvti 5sp
hello ,sorry to bother you guys but i have been successful in using the c60 celica gears in my yaris c50 ,i could only use gears three , four and five ,the shaft of the c 60 is the same as the c50 except it is a little longer (for sixth gear ) , i also used a 4.31 off a first gen xb. I have also swaped internals out of a 09 corolla c59 into a xd case to get 4.31 final and a closer 1st and 2nd gear. i didn't want to cut the frame to get a c60.
froger is offline   Reply With Quote
Old 11-03-2014, 05:23 PM   #66
xnamerxx
0-60 in slow
xnamerxx's Avatar
Do the gears just press on or is there more work involved using the C60 3-4-5 gears?
Old 11-03-2014, 09:38 PM   #67
froger
they just press in but i think you had to use the yaris synchros and sliding sleaves not the c60 celica ones
changing gear from robotic to automatic mariann DIY / Maintenance / Service 13 12-09-2011 07:43 PM
Gear Ratios J_T Performance Modifications 1 06-16-2011 01:31 AM
Changing Gear Oil Of the C160 Parmas DIY / Maintenance / Service 12 01-20-2011 03:44 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
Gear Ratios? aephilli DIY / Maintenance / Service 3 04-12-2007 06:38 PM
