Old 08-30-2014, 04:17 PM   #127
spookybathtub
Drives: 2007 Yaris HB
Originally Posted by CoryM View Post
Make sure your vent is clear as well. The transmission has a vent on it to allow for the expansion of the oil/air inside. Otherwise the seals have to deal with the pressure and will eventually fail. These vents often clog, and mine was plugged when I got the car with 38000km on it. A good indicator it is plugged is you will hear a hiss of air as you open the fill plug.
Cory, how did you clean the vent? When I removed the filler plug, some air hissed out, so apparently my vent is clogged. From the photo you posted, I can't figure out where it is. Is the vent a bolt, or simply a hole? Can it be cleaned with a squirt of compressed air?
spookybathtub is offline   Reply With Quote
Old 08-31-2014, 12:42 PM   #128
tmontague
tmontague's Avatar
I wouldn't mind knowing where that vent is either. I have changed my trans oil at 87,000km when I got my Yaris but will be doing it again before the winter as I'm at 122,000km and I want to put synthetic in. I didn't hear any air release the first time I did it but I'd like to check it.
Old 08-31-2014, 01:02 PM   #129
spookybathtub
I looked around yesterday, and I think I found it where Cory labeled in that drawing. After removing the air box, it's visible from the top. It's an aluminum cap about 1/2" diameter and 3/4" tall. It spins freely, and I pulled it off with vise grips. It looked totally clean under the cap, but I blew it off with canned air anyway.
Old 09-08-2014, 08:19 PM   #130
donpalino
Drives: Yaris 2010 5Dr MT
A suggestion to all owners, but specifically while doing this job:
I can't recall exactly where the vent is on these cars. iirc it's just behind the shifter. A little white(?) plastic knob that you twist and wiggle a little to free up any junk.
I'll try to find a picture.
Cheers.
Driving a 2010 Hatchback, 5 door, manual with 80K miles
Came back from the dealer after replacing the axle seal, which showed some leaking. Opened the filling cap and heard the hiss so I am sure I have to clean the vent. Now waiting for the MT-90.
Thanks for all the inside info.
donpalino is offline   Reply With Quote
Old 09-08-2014, 09:59 PM   #131
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
And now ur gone have to replace it with new ...they are not to be removed ,caps that is ...if stuck spray penetrating fluid free it up clean off with brake clean .
They are also used on the axles on Tacoma and tundra almost all Toyota's .
sent from my S4 on Mars
Old 09-08-2014, 10:00 PM   #132
spookybathtub
Mine went back on just fine... what's the problem?
Old 09-08-2014, 10:09 PM   #133
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
No problem... Just saying no need to take it apart and risk damage yours may or maybe not ok that's all
Old 09-16-2014, 09:58 PM   #134
donpalino
Found this pdf about multiples oils. Keep in mind is sponsored by AMSOIL. Also ignore the rating at the end. Kind of crappy weighting system.
http://www.syntheticwarehouse.com/br...lube_study.pdf
Old 02-12-2015, 06:36 PM   #135
attrapereves
Drives: 2010 Yaris 2dr 5spd
Just changed mine. I used RedLine. There is a noticeable difference in shifting.
attrapereves is offline   Reply With Quote
Old 07-18-2015, 03:46 PM   #136
valchrist90731
Drives: 2007 toyota yaris sedan
Originally Posted by Henry G. View Post
Royal Purple is average stuff at best. Read the technical reviews.
Redline MT-90 is top notch stuff. This is a 15 minute job at worst if you have the right tools. You will notice smoother shifting and that grinding while going into reverse will all but disappear. Its a no brainer especially if you drive 25k miles a year like I do.
If your grinding while shifting into reverse. Learn from your mistakes. Put the car into first gear then shift it in reverse. Grinding is due to the driver most of the time.
Have patience with your car and it will drive smoother.
This was to inform all on how to reduce grinding when shifting into reverse.
This was written respectfully as possible.
valchrist90731 is offline   Reply With Quote
Old 10-25-2015, 07:53 PM   #137
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Just got two quarts of the Redline MT-90 GL-4 Transmission fluid from ebay for $34 shipped. Hopefully it fixes my occasional second gear and reverse gear grind.
07liftback is offline   Reply With Quote
Old 10-25-2015, 08:45 PM   #138
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I will be as respectful as possible as well. This issue with shifting into reverse with the stock or other conventional fluod is a known issue. Expecting someone to shift into first just to shift into reverse is unacceptable. Telling someone to be patient isn't a cure to the problem. Sure, it is possible that drivers are over anxious to shift, but the issue has even been noted in published reviews. Once again reviewers could be over anxious to shift, but they have experienced many many manual transmissions in most cases so they have firm ground to stand on regarding the behavior. I have driven a few dozen different manuals from various vendors and have experienced this only on well worn transmissions not brand new ones. I had the issue within the first 1000 miles. Changed to synth and bam, resolved. There is a reason why so many manufacturers are switching to even requiring synthetic; it is a much more tolerant and better working lubricant.
Sent from my SCH-I545 using Tapatalk
Old 10-28-2015, 10:56 AM   #139
tmontague
tmontague's Avatar
Just sources some Redline MT-90 from a local store near me for $21 a quart, not too bad a price. I'll be picking it up later this week and putting it in this weekend.
I get a slight quick grind when shifting into reverse in the morning in my driveway and I'm currently running 75w90 synthetic. Not much better than oem just a little thinner in the dead of winter.
I'll leave my thoughts on here once I test it out.
Old 10-31-2015, 09:19 PM   #140
tomm9050
Drives: Yaris 2008 HB
GL-4 or GL-5 WHat's the difference. What's the verdict on what's best?
Thx
tomm9050 is offline   Reply With Quote
Old 11-01-2015, 09:58 AM   #141
tmontague
tmontague's Avatar
GL-4 seems to be what give much smoother shifting over GL-5. I've installed my GL-5 tranny fluid but haven't driven the car to try it out yet.
Old 11-03-2015, 04:27 PM   #142
tomm9050
What about Amsoil 75/90? It only comes in GL-5. Any suggestions?
http://www.amsoil.com/shop/by-produc...?code=SVGQT-EA
Old 02-10-2016, 01:36 PM   #143
strandrrs
Drives: 2009 Yaris 5-door Hatch
Can transmission fluid just be added at the dipstick entry for auto?
Hi -
I have a 2009 5-door hatchback Yaris.
Thanks for the great DIY instructions and photos - so helpful.
Can I just add the Toyota transmission fluid there? Do I have to drain it? If so, can I drain it from the bottom, the same way as the manual?
Thanks so much!
strandrrs is offline   Reply With Quote
Old 03-05-2016, 06:39 PM   #144
Aclosefriend
Drives: 2008 2dr Yaris Hatch
Thanks for this. I bought a 08 Hatchback a few months ago with a 5 speed MT with 65k miles. This was so easy and the shifting is much much smoother now. Only took 20 minutes, and most of it was waiting for the fluid to drain and for the fresh thick gear oil to flow down the tube.
Aclosefriend is offline   Reply With Quote
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
