#127 | |
#128 |
I wouldn't mind knowing where that vent is either. I have changed my trans oil at 87,000km when I got my Yaris but will be doing it again before the winter as I'm at 122,000km and I want to put synthetic in. I didn't hear any air release the first time I did it but I'd like to check it.
#129 |
I looked around yesterday, and I think I found it where Cory labeled in that drawing. After removing the air box, it's visible from the top. It's an aluminum cap about 1/2" diameter and 3/4" tall. It spins freely, and I pulled it off with vise grips. It looked totally clean under the cap, but I blew it off with canned air anyway.
#130 | |
![]() Drives: Yaris 2010 5Dr MT Join Date: Oct 2009
Driving a 2010 Hatchback, 5 door, manual with 80K miles Came back from the dealer after replacing the axle seal, which showed some leaking. Opened the filling cap and heard the hiss so I am sure I have to clean the vent. Now waiting for the MT-90. Thanks for all the inside info. |
#131 | |
They are also used on the axles on Tacoma and tundra almost all Toyota's . sent from my S4 on Mars |
#132 |
Mine went back on just fine... what's the problem?
#133 |
No problem... Just saying no need to take it apart and risk damage yours may or maybe not ok that's all
#134 |
Found this pdf about multiples oils. Keep in mind is sponsored by AMSOIL. Also ignore the rating at the end. Kind of crappy weighting system.
http://www.syntheticwarehouse.com/br...lube_study.pdf |
#135 |
![]() ![]() Drives: 2010 Yaris 2dr 5spd Join Date: Jan 2015
Just changed mine. I used RedLine. There is a noticeable difference in shifting.
#136 | |
![]() ![]() Drives: 2007 toyota yaris sedan Join Date: Jun 2015
Have patience with your car and it will drive smoother. This was to inform all on how to reduce grinding when shifting into reverse. This was written respectfully as possible. |
#137 |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
Just got two quarts of the Redline MT-90 GL-4 Transmission fluid from ebay for $34 shipped. Hopefully it fixes my occasional second gear and reverse gear grind.
#138 | |
Mr. 155 and climbing
Sent from my SCH-I545 using Tapatalk
#139 |
Just sources some Redline MT-90 from a local store near me for $21 a quart, not too bad a price. I'll be picking it up later this week and putting it in this weekend.
I get a slight quick grind when shifting into reverse in the morning in my driveway and I'm currently running 75w90 synthetic. Not much better than oem just a little thinner in the dead of winter. I'll leave my thoughts on here once I test it out.
#140 |
![]() ![]() Drives: Yaris 2008 HB Join Date: Sep 2007
GL-4 or GL-5 WHat's the difference. What's the verdict on what's best?
Thx |
#141 |
GL-4 seems to be what give much smoother shifting over GL-5. I've installed my GL-5 tranny fluid but haven't driven the car to try it out yet.
#142 |
What about Amsoil 75/90? It only comes in GL-5. Any suggestions?
http://www.amsoil.com/shop/by-produc...?code=SVGQT-EA |
#143 |
![]() Drives: 2009 Yaris 5-door Hatch Join Date: Feb 2016
Can transmission fluid just be added at the dipstick entry for auto?
Hi -
I have a 2009 5-door hatchback Yaris. Thanks for the great DIY instructions and photos - so helpful. Can I just add the Toyota transmission fluid there? Do I have to drain it? If so, can I drain it from the bottom, the same way as the manual? Thanks so much! |
#144 |
![]() Drives: 2008 2dr Yaris Hatch Join Date: Sep 2015
Thanks for this. I bought a 08 Hatchback a few months ago with a 5 speed MT with 65k miles. This was so easy and the shifting is much much smoother now. Only took 20 minutes, and most of it was waiting for the fluid to drain and for the fresh thick gear oil to flow down the tube.
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 10:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 02:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 09:37 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-08-2006 12:21 AM |
