Old 10-07-2014, 09:13 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
How long did your clutch last?
My 08 sedan just turned 180K kilometers, no problems with the clutch at this point,was wondering how long before i can expect to replace it, and whats a ball park figure of cost.
Thanks
Have Yaris will travel..
Old 10-07-2014, 09:26 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
It is a couple hours to drop the transmission to change the clutch and put it back. So you are looking at 500+$ already.
Old 10-07-2014, 09:40 AM   #3
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Got 1KR-FE engine (1.0) Yaris 2009 build in france.
Got 81k's on it... clutch still going strong... If my clutch is going to slip once in a while I'm going to change it.
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 10-07-2014, 09:51 AM   #4
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
Mine had 116k miles when I replaced it back in April. Still had life left but it was definitely slipping.
Sent from my iPod touch using Tapatalk
BobTheYaris is offline   Reply With Quote
Old 10-07-2014, 12:51 PM   #5
bronsin
bronsin's Avatar
A clutch in my experience will last forever if you dont abuse it.
But then again, those were in engines that were throttle by cable, not throttle by electrical wire. The throttle response in my 09 with auto makes me wonder if its possible anymore...
Old 10-07-2014, 01:04 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
A clutch should last a long time, provided only one person drives your car.
My car has been used for as many as three people at some point and the clutch wears down much faster in those cases. I've already gone through 3 clutch kits on my Yaris.
Old 10-07-2014, 11:44 PM   #7
nookandcrannycar
...297,455 miles and counting on my original clutch.
Old 10-08-2014, 01:50 AM   #8
Yaristeve
Drives: 3-door hatch
2011 3-door, four years, 114,000 miles, and no problems. I test it occasionally by short shifting from first to fourth (gently). Plus my 35mile (one way) daily commute includes two fairly long inclines each way, in fifth gear. Still no signs of slipping. However, I can tell it is worn significantly since the pedal is somewhat stiffer than when I first got the car.
Toyota yaris 2002 - Hard clutch abhinav_kr DIY / Maintenance / Service 10 06-29-2016 07:08 AM
'07 Yaris Clutch replacement dinop DIY / Maintenance / Service 12 04-22-2013 04:47 AM
Clutch question. Black_griffin6 Performance Modifications 6 04-04-2013 04:30 PM
Clutch pedal assembly interference with foot Connoisseur_of_fine_cars General Yaris / Vitz Discussion 4 09-23-2011 10:57 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
