Old 03-04-2015, 12:19 PM   #1
HartmannX
Drives: Yaris 2003 1.4 D-4D
Fog lights as DRL ?
Hello all!
Planning to replace my DRL from the headligts to the fog lights.
I have a European model Yaris 2003 (Facelift) NLP10 1.4 D-4D, JTD VIN.
Have someone done this before? A the moment i did not check out the wiring diagram yet!
Another story:
At the same time when the DRL is relocatet, i think i also will mount a aftermarket timer relay, for the use of "follow me home" exterior light, when a unlock with remote, and maybe also when i lock or stop the car.
Best regards!
HartmannX is offline   Reply With Quote
Old 03-04-2015, 06:21 PM   #2
The DRL is the headlight bulb itself, so to feed the fog lights instead you would have to cut the feed wire from the DRL relay (under the dash) and run it to the fogs instead.
Old 03-04-2015, 07:06 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Don't forget the DRL feed is pulsed at 12v. When I fed it directly to the fog light switch, if flickered the fog relay. A small capacitor fixed the issue.
Old 03-04-2015, 08:32 PM   #4
That output shouldn't go to the relay - It should go directly to the bulb.
Old 03-05-2015, 01:19 AM   #5
HartmannX
You both confirmed my thoughs. Have to check up at the pulse signal, in Denmark where i live the Yaris have full power/light in tje headlights whit standard DRL. Mayby its because the headlights are using H4 bulbs, whit combi low/high beam...?
Old 03-05-2015, 06:42 AM   #6
IllusionX
I wanted it to be switched. So I connected the feed to the Orange wire of the DRL module.
Old 03-05-2015, 06:49 AM   #7
HartmannX
It is also a solution.
Have big was the capacitor you used?
Old 03-05-2015, 08:26 AM   #8
IllusionX
Fog lights as DRL ?
Very small. 100uf I think. It's been a while.
But that's one more component that could fail. CTScott's way is the proper way to do it.
My fog light indicator is always on on my dash
Old 03-05-2015, 11:53 AM   #9
HartmannX
Okay, thanks for the info.
Old 03-05-2015, 11:55 AM   #10
HartmannX
Will take a closer look at the wiring diagram when i got the time :-D
Old 03-08-2015, 06:21 AM   #11
HartmannX
Can somone take a look at the diagram, have a little trouble to find the right signal wire i have to move to the fogs, it seems the the power from DRL relay runs the headlights..
https://www.dropbox.com/s/dic3dfmw0a...06.19.jpg?dl=0
https://www.dropbox.com/s/xt63k3wgy4...09.04.jpg?dl=0
Old 03-08-2015, 09:03 AM   #12
IllusionX
I don't think i can guide you there. This diagram doesn't look like what we have here for a 1st gen.
Old 03-08-2015, 09:31 AM   #13
HartmannX
Hm.. My head hurts...
Old 03-08-2015, 11:19 AM   #14
IllusionX
Here is what my DRL module looks like in the diagram on a 05 echo.
Old 03-08-2015, 11:23 AM   #15
HartmannX
What VIN number do you have, JTD, VNK or?
Old 03-08-2015, 01:33 PM   #16
For the MK1 European Yaris it looks like the DRL module is far more integrated than for the US/Canada market ones. I recommend instead wiring the fogs via an ignition switched relay to make them act as DRLs.
Old 03-08-2015, 02:05 PM   #17
HartmannX
Thats my problem, the lights are also manget by a plus signal, not by the minus. Hm... Mayby its not worth the time
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 54 Yesterday 08:40 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
