Old 01-08-2016, 01:56 PM   #1
RutherfordmanX
Drives: 2017 Yaris Hatchback
Question about brake booster replacement
So in searching some of the older threads I think I am starting to get the early signs of the brake booster going. When I come to a stop I can feel the idle stumble for a second or two and then go back to normal. It actually started doing it a while back and is slowly getting a little worse but does not do it every time I stop. Still not real bad though. So is it safe to assume when you replace the booster you have to disconnect the brake lines from the master cylinder and bleed the entire system? Do you have to remove other parts to get the booster out since it is way up in there behind the master cylinder. Done brake boosters before but on much older vehicles (1975 era). Just wondering what I am up against when the day comes. Cant believe it is going out with only 320,000 miles on the car
RutherfordmanX is offline   Reply With Quote
Old 01-09-2016, 12:34 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
I've not done a Yaris, but it's very unusual to need to disconnect the hydraulic lines. Typically you just unplug the vacuum hose, unbolt master from booster (and pull it out of the way with brake lines still attached), disconnect pedal, unbolt booster.
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
another brake question swidd DIY / Maintenance / Service 10 06-20-2010 06:51 PM
Brake question xen555 DIY / Maintenance / Service 8 03-06-2009 06:14 PM
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 06:32 AM
replacement bulb question justinparadise21 Cosmetic Modifications (Exterior/Interior) 2 11-06-2008 02:52 AM
