Old 02-23-2016, 08:39 PM   #19
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Originally Posted by tmontague View Post
where are you guys finding the rpm package listed? I'm struggling to find the proper set up on line anywhere
You can find the Scion XD RPM setup here: fastscions.
The only make it for the 2zrfe, if you were searching for the 1nzfe, that might be why you are having trouble finding it.
I got the axles popped out, but left them in the knuckles because the axle nuts were so rusted up. I have the struts off, so at least they have a bit of wiggle room.
So all I gotta do is unhook the fuel rail connector, and undo the three mounts and I should be good to take the engine out.
I am planning to lift it by the outer two mounts.
I removed the lower tie bar also for more room.
I am thinking I just might fab up a midpipe myself. I am so torn, I was kicking around getting the OBX catless system and welding in a new flange and cat, but it is stainless, and I don't know how tricky stainless to mild steel would be to weld.
brushforhire is offline   Reply With Quote
Old 02-23-2016, 08:51 PM   #20
tmontague
tmontague's Avatar
spray the crap out of the axle nuts with some PB Blaser a few times each day. Then when everything is back installed used a massive breaker bar or preferably an air gun. Better to spend the time now and release them before it becomes too late and you can't when you need to.
When I installed my rear axle spacers the hubs needed to be air chiseled off. It was a huge pain but I was glad I did it. After re installing with proper anti seize when ever I needed to change my rear hub I can do so relatively easily.
The other option to pull the engine is to go to the dealership and get the 2 engine hoise hooks with 1 bolt each that mounts into the front passenger side and rear drivers side of the engine. However, you way should also work fine, the engine is light.
Old 02-24-2016, 05:02 PM   #21
brushforhire
Woot! Engine and trans came out this morning.
Received the engine and most of the parts today at work. In the truck waiting to get unloaded. Still gotta collect a few oddball pieces and I will be good to go.
I went ahead and ordered a Takeda cold air intake, for this. Along with my Megan coilovers. Still kicking around what I want to do for the exhaust.
Old 02-24-2016, 06:45 PM   #22
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Awesome!!
ArmstrongRacing is offline   Reply With Quote
Old 02-24-2016, 07:35 PM   #23
beaker
Drives: 07 Yaris 3 door
I know it's pricey, but you have got to go with the RPM setup. Gotta see how much can be squeezed out of this motor.
beaker is offline   Reply With Quote
Old 02-24-2016, 08:14 PM   #24
tmontague
tmontague's Avatar
^i second that. The RPM exhaust is a beauty piece and I have a feeling it'll be good for some gains. Keep in mind the 2zr is going in an extremely light car meant for a weaker engine so even small gains will be felt pretty good.
I'm convinced when my engine start to burn oil in the next decade i'll be swapping in a used 2zr instead of re building and installing a Blitz s/c. As much fun as a boosted set up would be an additional 30 hp/tq all engine would be better
Old 02-25-2016, 11:41 PM   #25
ArmstrongRacing
Data doesn't lie
If the 2zr responds to headers like the 1nz does....you can expect gains of 10+Hp!
http://www.yarisworld.com/forums/showthread.php?t=11821
Old 02-26-2016, 02:02 PM   #26
brushforhire
Just a small update, the Takeda intake won't work because it reuses the factory MAF sensor tube, and I don't have that. This was not mentioned anywhere in the auction.
Ordered a flexplate from ebay, so that should hopefully be here soon.
Old 02-26-2016, 03:59 PM   #27
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Sure enough, the pics on the aFe website show the OEM MAF tube in there. What a weird thing to do.
Old 02-26-2016, 06:46 PM   #28
brushforhire
Yeah, I didn't realize that it was the oem piece until I had it in my hands and realized they wanted you to reuse the stock piece. I would have expected better considering that it wasn't a cheapo intake. The seller is working with me to try and find me one though.
I get why they did it though, easier than trying to figure out the correct mounting and depth of the MAF. From what I was reading alot of the intakes don't mount the sensor at the correct depth and it throws codes. I noticed alot of the other intakes having a smaller section where it mounts to make up for this. Which seems weird to just have a bottle neck in there like that.
Old 02-26-2016, 07:07 PM   #29
CrankyOldMan
The real bumer is that you can't find them cheap on eBay, and they're too new to be in you-pick-yards.
Old 02-26-2016, 10:28 PM   #30
ArmstrongRacing
Data doesn't lie
The cheapest stock airbox I found was $120....On Ebay
Old 02-27-2016, 07:44 AM   #31
brushforhire
The seller actually found a piece from another toytota for $39 shipped that looks almost exactly the same. They are refunding me $20, to help pay for it. So I will give it a shot and see what happens.
Either way I will keep you updated.
So I am waiting on the flexplate, that intake piece, and trying to figure out what I want to do for the exhaust. I am thinking I am just gonna pull the trigger on the RPM long tube setup. I have my welder, but by the time I piece out the cat, flex tube, flanges, o2 bung, resonator, etc. I will be probably over halfway there anyways.
In the meantime I'm gonna finish cleaning up the engine bay, and then probably just spray it all black.
I did get the passenger side axle out. The drivers side it probably gonna stay in. The end no longer even has threads, just rusted solid. The passenger side came out with relatively little effort, considering the miles on it.
I did notice alot of my bushing are looking rough. I am thinking it's time for whiteline bushing kit.
I will try and get some currect pics up later today.
Old 02-27-2016, 12:32 PM   #32
ArmstrongRacing
Data doesn't lie
Good work man!
Old 02-28-2016, 06:15 PM   #33
brushforhire
Okay well slow progress going on, and a bit of a surprise.
Here is the car in it's sorta current state:
The wheel well:
Working on cleaning as much as I can, I would like to spray it gloss black just to give it another coat and protect it a bit.
The surprise was that I actually managed to get the drivers side axle out.
The rusted mess:
I didn't think there was anyway that nut was ever going to come off, but I kept messing with it. I actually tried to tighten it, and then hit it real quick in reverse and I started to come right off.
This tool was some of the best money I ever invested:
Ryobi one+ 1/2 impact. I have really worked it hard, and it just keeps going. I used it to take the rear end off of my 2000 tundra, and it plowed right through the rusty bolts and nuts there, too.
Some of the other tools I am using to do this job, just so people can see what it takes to do this:
The old engine and new engine:
I will be buying a tap and die kit to redo a number of the smaller 10mm bolts that snapped right off, trying to take them out.
It really is just basic tools that anyone should have, if they are considering doing this themselves.
So far this has been an interesting job, seeing as that I am doing it completely solo.
I was hoping to have this done in the next week, but I am gonna take my time and work on fixing the bushings and any other small stuff I find to save me from having to tear this stuff down again.
Old 02-28-2016, 07:33 PM   #34
Frank the Tank
Drives: 2007 Toyota Yaris
How much was the engine lift? There's one at my work that hardly gets any use that maybe my boss can lend me when I get this going (which won't be for a while. Suspension, brakes and tires are first on the list)
Frank the Tank is offline   Reply With Quote
Old 02-28-2016, 07:46 PM   #35
ArmstrongRacing
Data doesn't lie
Youre supposed to unbolt the torque converter from the flexplate, not pull it out of the trans. Haha. Otherwise good work!
Old 02-28-2016, 08:41 PM   #36
brushforhire
The engine lift ran me $180. I got it on sale at harbor freight. I like it because the front legs fold up for easier storage. It is the tow ton lift. The 1 ton lift is usually $180.
LoL, I kinda wondered that after I got it apart.
For future reference I would unbolt the torque converter in the car, because it is a pain to get to the underside of the engine while hanging from the lift.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
60/40 to Bench Seat Swap Issue CTScott Cosmetic Modifications (Exterior/Interior) 24 11-26-2012 02:45 PM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
