Old 07-09-2017, 11:20 PM   #1
turblown
Drives: 2010 Toyota Yaris Sedan
Uneven Tire Tread Wear?
All four tires have uneven tire wear in the center of the tread. Currently the tires are measuring approximately 4/32" on the inner/outer tread and 3/32" on the center tread. I know this is normally caused by over inflation, but they are at the recommended pressure of 32psi.
What could cause this type of uneven tire tread wear?
Should a different tire pressure be used due to going with larger than stock tires and rims? Do tires tend to wear unevenly towards the end of life? Is it possible that these are just crappy tires? Is there a mechanical failure that would cause this?
  • 2010 Yaris Sedan with 135k miles
  • TRD Rear Sway Bar with 85k miles
  • TRD Springs with 26k miles
  • TRD Shocks with 26k miles
  • 205/50/16 Goodyear Assurance Fuel Max Tires with 43k miles
  • MB Weapon Gunmetal Rims 16"x7" ET38 with 43k miles
  • All other steering/suspension components are STOCK
  • Tires rotated and balanced every 5000 miles.
  • Vehicle aligned every 5000 miles.
  • Tires maintained at stock 32psi.
2010 Yaris Sedan: TRD Air Filter, TRD Sport Exhaust, DC Sports Headers, NST Pullies, TRD Springs, TRD Shocks, TRD Rear Sway Bar, TRD Oil Cap, TRD Radiator Cap, 205/50/16 Pirelli Tires, MB Weapon Gunmetal Rims 16"x7" ET38, Tint.
Wishlist: ZAGE Turbo Kit.
turblown is offline   Reply With Quote
Old 07-10-2017, 12:45 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I would not define a difference of 1/32" as "uneven" wear. This is not something that I would be worried about. You are however nearing the end of useful threadlife for those tires. Not yet, but soon.
NYC-SE is online now   Reply With Quote
Old 07-11-2017, 12:55 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^^ What NYC-SE said.
At this point in the tyre's tread life, you're talking about less than 1mm difference across the tread. I don't think there's need for concern there.
Old 07-11-2017, 09:09 PM   #4
SirDigby
Drives: 2007 yaris 3 door
you are in phoenix, and it is hot. your pressure IS higher because of your environment. if you ran at 28-30psi they will run more even, but overall they may wear faster. you will have better traction and breaking. it depends on what your end goal is....
buy a tire with a UTQG of 500(+) A or AA, A and run at 30psi. you will be happy on both sides of wear and longevity....
(IMO)
Uneven wear after rear spacers Focus_Sh1ft Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-16-2013 01:17 PM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire Wear Analysis Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-13-2009 09:28 AM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
