Old 05-15-2013, 04:36 PM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
Uneven wear after rear spacers
For once, I have a problem that isn't engine/forced induction related
I installed 10mm Penguin Garage rear spacers a little over a month ago. Recently I noticed an unusual wear pattern on my rear tires. I have an idea of what the problem is (and it really isn't a big deal if so), but I'd appreciate some feedback.
Wheel/tire spec: 15x7 +37 Oz Superleggera with 205/50/15 Yokohama S Drives.
Pretty sure I installed the spacers correctly, but I didn't use the four washers that were included... Mainly because I had no idea what purpose they served.
Note: The wear pattern is only on the outside of the tire. Rotation is correct.
Old 05-15-2013, 05:00 PM   #2
It appears that the tires are rubbing on the fender. That's my guess.
Old 05-15-2013, 05:03 PM   #3
Here was my tires after driving for less than 3 miles with a total of 4 people in the car:
I semi rolled the fender lips, and that solved the rubbing issue.
Wheel specs on those were 17x7.5, ET38 with 205/40/17 tires that ran more like 215/40/17 tires.
Old 05-15-2013, 05:04 PM   #4
That is the tires rubbing on the fender.
The cut washers, two per side, on the lower hub bolts only, add about 1 degree of negative camber.
** And would probably solve your rubbing problem. **
Question though -- you don't hear the tires rubbing? Got that trance music pumped up?
Old 05-15-2013, 05:13 PM   #5
http://www.youtube.com/watch?v=ime1P9mA-ZQ
Old 05-15-2013, 09:40 PM   #6
Focus_Sh1ft
Thanks guys. That was my thought too, except I didn't realize it until I had the OP completely ready to post lol.
Thanks for the clarification on the washers!
Also, this.
Because I really... Didn't hear any rubbing. I think that just means I'm doing it right.
Old 05-16-2013, 01:17 PM   #7
lol. just to be clear, I am talking about the cut washers. The eight lock washers are used with all of the bolts.
Rear hub spacers Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-01-2010 11:54 AM
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 09:54 AM
