![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
oil change - synthetic blend really?
the local o'reilly auto parts had a special oil/ filter for $19.99 so i decided to do a change before the maintenance light came on at 4500 miles
then when completed noticed "synthetic blend" on the label. Somehow i doubt its true only because the real synthetic oils ive seen advertised are much more expensive and whats this "high mileage" note about? for engines over 75000 .... ![]()
![]() ![]() ![]() Drives: 2016 Yaris 3 Dr Super White Join Date: Mar 2016
All I know is that I pit some of that in my old Rav4 and it started smoking on startup. I have no idea if it was a direct result of that oil, but it had never done that before. I had 76,000 miles on a 1999 Rav4. Those engines were known for that problem though.
That's not full synthetic. It's a blend of synthetic and conventional oil. I wouldn't use that for very long on your '16 since I believe full synthetic must be used. Also, I believe the manual calls for 0w-20 grade as well.
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Recommend synthetic oil? Change at 3k or 5k | caaront | DIY / Maintenance / Service | 36 | 03-02-2015 09:22 PM |
| Quick 2007 Yaris oil change question | desidude | DIY / Maintenance / Service | 27 | 02-19-2015 05:54 PM |
| Planning first oil change @ 500 or 1000mi | schleppy | DIY / Maintenance / Service | 39 | 07-09-2010 06:28 AM |
| Oil Change Issue. | Twistoffate0817 | General Yaris / Vitz Discussion | 56 | 05-05-2009 10:27 AM |
