Old 01-12-2023, 11:50 PM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
1nz-fet TRD
Seen this Axios GT with TRD 1nz-fet for sale here in New Zealand and thought I would post the engine bay as I myself had seen the turbo engine but not the trd turbo version and that pipe work is awesome!
I want this motor and ecu.
Compeer is offline   Reply With Quote
Old 01-13-2023, 01:47 AM   #2
sh0rtlife
the hell is an axios?
i was looking at the enginebay thinking why is everything in the wrong spots and moved a lil..then i spotte dthe headlights...started thinking its an echo?
regardless its cool to see a trd 1nz....id like the pieces
Old 01-13-2023, 01:04 PM   #3
Compeer
Weird little japanese only Corolla offshoot, the turbo 1nz-fet is rare but this trd one is cool as, heres the exterior..not so cool i think the yaris vitz is way cooler looking it just needed this motor.
Old 01-13-2023, 01:25 PM   #4
sh0rtlife
very yaris hood and partial bumper, id almost waged that clip would fit or could be slightly altered to fit...i do like the headlights better
plumbing it for an IC would be tricky
Old 01-13-2023, 01:49 PM   #5
Compeer
Nah thats an intercooler on the front, the trd twin pipes go over the motor down to the turbo and then back over to the intercooler and then into the stock intake.
Its tiny, its the same one front mounted thats normally top mounted.
Old 01-13-2023, 09:59 PM   #6
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Its too bad the 1NZ is pretty much maxed out on the bottom end with the TRD turbo variants.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 01-14-2023, 03:04 AM   #7
sh0rtlife
so your telling me both of those shiny black pipes goes to an intercooler?
Old 01-15-2023, 05:26 AM   #8
Compeer
Yeah, its tucked in behind the radiator.
Old 01-15-2023, 02:53 PM   #9
sh0rtlife
weird
the more i look at it the more i question if its even possible to use that stuff on a yaris thats LHD ...look to the right EVERYTHING is in a weird spot and relocated
Old 01-16-2023, 03:37 AM   #10
Compeer
Does the 1nz-fet have the same conrods? Turbo variants normally have stronger conrods and deep dished pistons in my experience but have not been able to find info on the 1nz-fet as they are so rare.
weird
Haha yeah but yours is the weird relocated one! RIGHT hand drive
Old 01-16-2023, 10:40 PM   #11
sh0rtlife
i dunno..id say there probably just as may LHD as RHD....just the RHD's got more engine size options including 4wd, and more of the "performance" version
10-1 odds are the slugs are indeed different as a lowwer comp is generaly REQUIRED with turbo to make it survive and pass emissions requirements..but the con rods are not always different
but with the VVT being able to tweak the cams into bleeding compression or adding to it..they may not have neeeded to change the slugs even..just re-tune the brain and change the VVT timing
im very curious of it myself
Old 01-17-2023, 02:47 AM   #12
Compeer
Yeah if thats the case, the ECU is what you would want from one, everything else is easy and at that point may as well get a fancy aftermarket ecu with vvti and get it tuned, thats the dream haha
I keep looking at second hand aftermarket ecu but im not sure what to get or where to go to get it tuned etc.
Old 01-17-2023, 12:33 PM   #13
sh0rtlife
from what ive learned..unless youve got a ton of disposable money to burn on a dyno....try and stay close to stock with small mods..which means if you want to turbo swap find a turbo ecu
Old 01-18-2023, 08:31 PM   #14
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Yes, to my knowledge the bottom end is the exact same as a regular 1NZ-FE, compression ratio is still ~10.5:1. AFAIK all they did was put a small turbo on it with a safe ~6psi or so of boost and send it out the door.
2014 NCP131 5 Speed
Old 01-18-2023, 10:20 PM   #15
sh0rtlife
that begs the other question is the ecu different?...i mean if its the same bottom end and comp, looks like the intake is the same too...cams?
whats genuinely different?...besides the obvious like the intake tract including the turbo..yet the manifold looks like it might even be the same
Old 01-19-2023, 08:10 PM   #16
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
I'm betting the ECU is different, or at least the tune is but I can't confirm anything. I'm kinda just going off speculation and what little info I can find on the interwebs lol
2014 NCP131 5 Speed
Old 01-20-2023, 08:40 PM   #17
sh0rtlife
sad part is alot of the info either doesnt exist or just "hints" at it..nothing solid and it sucks
Old 01-21-2023, 03:13 PM   #18
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Import one and pull it apart lol
2014 NCP131 5 Speed
Vitzoomph TRD turbo M TTM Photo-Video-Media Gallery 19 02-01-2017 01:43 PM
Found on ebay: TRD turboed 1nz engine ezhacker1 Performance Modifications 7 08-02-2014 07:23 PM
TRD exhaust hanger issues....check yours Gogogordy DIY / Maintenance / Service 4 11-08-2012 08:22 AM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 02:52 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 11:51 AM
