![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
1nz-fet TRD
Seen this Axios GT with TRD 1nz-fet for sale here in New Zealand and thought I would post the engine bay as I myself had seen the turbo engine but not the trd turbo version and that pipe work is awesome!
I want this motor and ecu.
the hell is an axios?
i was looking at the enginebay thinking why is everything in the wrong spots and moved a lil..then i spotte dthe headlights...started thinking its an echo? regardless its cool to see a trd 1nz....id like the pieces |
#3 | |
very yaris hood and partial bumper, id almost waged that clip would fit or could be slightly altered to fit...i do like the headlights better
plumbing it for an IC would be tricky |
#5 | |
Its tiny, its the same one front mounted thats normally top mounted. |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Its too bad the 1NZ is pretty much maxed out on the bottom end with the TRD turbo variants.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
so your telling me both of those shiny black pipes goes to an intercooler?
weird
the more i look at it the more i question if its even possible to use that stuff on a yaris thats LHD ...look to the right EVERYTHING is in a weird spot and relocated |
#10 | ||
#11 | |
10-1 odds are the slugs are indeed different as a lowwer comp is generaly REQUIRED with turbo to make it survive and pass emissions requirements..but the con rods are not always different but with the VVT being able to tweak the cams into bleeding compression or adding to it..they may not have neeeded to change the slugs even..just re-tune the brain and change the VVT timing im very curious of it myself |
#12 | |
I keep looking at second hand aftermarket ecu but im not sure what to get or where to go to get it tuned etc. |
from what ive learned..unless youve got a ton of disposable money to burn on a dyno....try and stay close to stock with small mods..which means if you want to turbo swap find a turbo ecu
Gen 3 > Gen 2
Yes, to my knowledge the bottom end is the exact same as a regular 1NZ-FE, compression ratio is still ~10.5:1. AFAIK all they did was put a small turbo on it with a safe ~6psi or so of boost and send it out the door.
#15 | |
whats genuinely different?...besides the obvious like the intake tract including the turbo..yet the manifold looks like it might even be the same |
#16 | |
Gen 3 > Gen 2
sad part is alot of the info either doesnt exist or just "hints" at it..nothing solid and it sucks
Gen 3 > Gen 2
Import one and pull it apart lol
| Vitzoomph TRD turbo M | TTM | Photo-Video-Media Gallery | 19 | 02-01-2017 12:43 PM |
| Found on ebay: TRD turboed 1nz engine | ezhacker1 | Performance Modifications | 7 | 08-02-2014 06:23 PM |
| TRD exhaust hanger issues....check yours | Gogogordy | DIY / Maintenance / Service | 4 | 11-08-2012 07:22 AM |
| TRD Options | S1L3N7 D3A7H | New YARIS Purchase Forum | 26 | 01-20-2009 01:52 PM |
| TRD Parts | MC-BPT | Sponsors Classifieds Area | 9 | 06-23-2007 10:51 AM |
