![]() ![]() Drives: Yaris 12 Join Date: Oct 2016
Speed sensor
Hello,
do you know where is the speed sensor on a 2012 Yaris L 1.5l manual transmission? I removed the battery mount once, but could not see anything resembling the speed sensor on the top of the transmission. I found a speed sensor on Rockauto, not sure it's the good one. |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
check this out. Take note of Left and Right part number
https://www.toyodiy.com/parts/s?v=U_...GMRKA&s=speed+
Thank you,
I found them on Amazon, and on Rockauto they are under Brake "ABS wheel speed sensor". I was looking under Electrical "Speed sensor". |
| Vehicle Speed Sensor Problems | jacl3 | DIY / Maintenance / Service | 1 | 06-23-2025 01:16 AM |
| Abs and slip indicator on need help speed sensor | Jeffbass | DIY / Maintenance / Service | 0 | 04-28-2016 01:38 PM |
| Rear Speed Sensor Install Help? (ABS Sensor) | towerofpower | DIY / Maintenance / Service | 2 | 04-07-2014 06:32 PM |
| Bad Speed Sensor? | dmehak | DIY / Maintenance / Service | 33 | 01-05-2011 09:17 PM |
