Old 08-08-2007, 08:36 AM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by grampi View Post
Not true. I can tell you from personal experience the pressure listed on the driver's door IS NOT the optimum pressure. I have found that running your tires at about 5 psi over the recommended pressure increases tread life, improves handling (stiffer sidewalls), reduces tire noise, and improves fuel economy. The only thing that's better at the recommended pressure is the ride, and even then, only somewhat better. Some people run their tires at the max pressure listed on the tire's sidewall, however I've found door pressure +5 is usually the best compromise between getting all the other bennies and a smooth ride.
well your statement as also not true, 5 psi over the recommend may cause roll over hazzards in some vehicles, the tires being too stiff will cause them to fail government safty rollover test, this was the case back with the whole Explorer/Firestone recall. no matter what tires on those mid to late 90's explorers they can not pass the rollover test with any more than 26psi in the tires. But if you know anything about tire load index's you know that 26 psi in a tire can not hold the weight of a small SUV... there inlied the problem... regaurdless, you have some holes in your theories
Old 08-08-2007, 09:40 AM   #2
grampi
Drives: Corolla
However, the rollovers being experienced by Explorer owners weren't due to overinflated tires. They were being caused by blowouts due to underinflated tires. Tire manufacturers would not list a max pressure on their tire's sidewall that's so much higher than the auto manfacturer's recommended pressure (this pressure is usually 44 PSI) if that pressure could cause safety issues. This would open them up to law suits. If there's a problem with any vehicle's handling with any tire pressure between the auto maufacturer's recommended pressure and the max pressure listed on the tire's sidwall, then there's a problem with that vehicle and it should not be allowed on the road. That problem wouldn't be due to tire pressure.
grampi is offline   Reply With Quote
Old 08-08-2007, 09:54 AM   #3
Black Yaris
der Zeck
I will give you that
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 10:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 12:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
