Isn't the OEM spring seat rubber? How would that red aluminum spring seat mate to the underside of the car? On the SK coilovers there was a similar aluminum spring seat but it required the use of the stock upper rubber spring seat.
#2 | |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
The red aluminum ring apparently mounts to the large rubber "sub assembly," which is part of the OEM unit as shown in the OEM diagrams. There are also some 1.5" metal spacers that came on the shock's pistons (they sit just below the threads on the top end of the shock's pistons), and I'm not sure if I should use them or not. I did not install them on the rears. I'll tell you this: Megan does NOT include a real set of directions with these, and the folks at Megan Racing weren't able to help much either.
Subcompact Culture: The Small car blog |
| Megan Springs? | churp | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 06-06-2007 03:11 PM |
| Megan or Tein suspension | elmercurrie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 43 | 05-31-2007 09:41 PM |
| Comp S Coilovers for a discount and installed | BulletProofAuto | California | 1 | 05-12-2007 01:04 AM |
| cusco coilovers installed | badhabitz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 02-03-2007 04:43 PM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
