Headlight Problem
I have this problem where every 3 months I have a headlight blow out...It seems that every time I drive more than 200 miles at a time I loose a headlight. Can anyone provide some insight? This is getting expensive! I even use a small bit of bulb grease ever time I change them!
#2 | |
![]() Drives: 2008 yaris hatchback Join Date: Oct 2008
I know they won't replace the bulb itself, but if there is a problem with the wiring??? |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
That is simply NOT true. I've been running 100 W. halogen lights for the last 25 years (in vehicles that came stock with 55 w. bulbs) and never had a short lifespan problem.
A short life in any halogen light is most commonly caused by a bad ground, by low voltage, or by excessive vibration. Examine all connections for dirty or corroded connections. You'll need a volt/ohm meter to check things out electrically. They're cheap, at $15 for basic models, or borrow one. |
Compulsive Washer
Maybe your/the mechanic's hands are always oily at the moment of bulb install? That's a pretty common bulb killer.
![]() ![]() Drives: 5spd 2007 Yaris LB Join Date: Jul 2007
do you do any type of snorkeling in the yaris?
lol D:
99.9% of what goes on in my mind at work/school/home ![]() [Debadged] [Tanabe DF210] [Limo Tint][17" Fondmetal Wheels] [Pioneer HU] --:: Wishlist, PM me ::-- [SSK (WTB)] [Black Sand Pearl Eyelids (WTB)] |
good point...but not sooooo recently that it would be a culprit...I mean would contact with water blow it out right away? I always use gloves and bulb grease when I install...No, I don't put the grease on the bulb ...just the connector...I use silverstar ultras....maybe I'll try a different brand to see if that is the reason |
o.o i didn't think you WERE actually snorkeling, holy jebus
"bulb grease"??? I've never heard of that... Does the bulb manufacturer recommend it? Maybe try installation without it.
| Gas pedal problem? | Befuddled | Performance Modifications | 28 | 01-27-2010 09:55 AM |
| Headlight Problem | sleuzze | General Yaris / Vitz Discussion | 1 | 09-03-2007 02:17 AM |
| Headlight fog | elsteverino889 | Cosmetic Modifications (Exterior/Interior) | 2 | 03-28-2007 06:38 AM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 06:00 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
