Old 10-30-2008, 03:53 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Drive by wire is on BOTH the automatic and manual... Essentially, it has nothing to do with the transmission. It is the electronic link between the gas pedal and the throttle body. No throttle cable, it's electronic...
PetersRedYaris is offline   Reply With Quote
Old 10-30-2008, 04:28 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
It is more pronounced in the auto because you wait for the throttle to respond, there there is a delay while the transmission downshifts.
Old 12-18-2008, 12:37 PM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Throttle response is SHARPER than on my cable linked cars. There is a lot going on in the ECU, not just throttle response. It will not go WOT if revs are low or timing retard due to ping/knock sense. Best thing you can do is keep the carbon off the piston tops (wail it and water it) and slippery oil in the cranckase with a real 88-90 ocatane quality fuel toikeep the timing at max adavance at low rpm; then it should be locked and loaded all times. This ecu will learn a FE mode due to driving style then you punch it and it says - FU guy! <or> THE SOLUTION: Take off the F.I. and put a string of Mikuni 28MM. from a crashed Suzuki 1000 cc GSX-R
- bro
TheSilkySmooth is offline   Reply With Quote
Old 01-02-2009, 01:06 AM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Yeah I have this problem too, especially while trying to pick-up speed while entering or transitioning freeways. I have to shift down one more gear to match the traffic speed and prevent a wreck, at the expense of temporary engine strain.
DBC conversion sounds good right about now
Old 10-30-2008, 05:22 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
what i meant was the lag may exist on auto but manual is very responsive depending on what revs ur on..
Old 12-28-2008, 06:15 PM   #6
dybbuk
dybbuk's Avatar
Drives: 2008 Yaris HB
I would say the same thing about my auto. If I'm driving conservatively(i.e. most o the time and punch it, there's a delay. IF I'm racing around town and keep the revs up the response is sharp as it can be.
dybbuk is offline   Reply With Quote
DIY: Replacing Stock Mirrors redyaris DIY / Maintenance / Service 30 04-20-2016 03:03 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
ICE Navigation Wire Question? duck In Car Entertainment + Electronics (audio / video / alarm) 11 10-25-2008 12:20 AM
kicker 1/0 gauge wire installed... punch In Car Entertainment + Electronics (audio / video / alarm) 1 07-25-2007 07:46 PM
