![]() ![]() ![]() ![]() Drives: 07 metmet LB Join Date: Oct 2008
so wait...his intake assembly is going to be behind the engine then?
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
![]() Drives: Yaris 4dr 2008 Join Date: Nov 2008
I guess, the turbo need to be very close in the exhaust piping, just above the oil level for oil drainback, so the air intake need to bring fresh unrestricted air there, pressurized and sent out front for cooling, back to the throttle body.
As far as fuel management, I just don't see how not to upset the computer, piggyback is a hell of a headache and not cheap, the adaptation of the ECU will mess the tune in a matter of hours, it need a complete reflash, or to run a standalone in conjunction with the present computer to run the acceesories, but the EMS will still be pissed off... The only ways I see to do this from now is either to run a 5000 $ Motec EMS or revert to cable throttle, hacksawing the whole throttle system and revert to pre historic engine control. To run a piggyback: EGO : we need to lie to the EMS, we need to control, O2 sensors signal so the ECU thinks that it's running right not detecting the over rich condition or it will trim the fuel gradually until maxed out, then will trigger limp mode MAF : Limit the MAF signal so the EMS don't detect overboost and trigger limp home maps, the ECU need to think he's running WOT Relying on a MAF signal mod will mess the timing tables, so the engine need to run as stock below 0 PSI Injectors : Intercept the injector signal modifying it to run larger injectors, the piggyback need to read Manifold pressure and compute pulse width Ignition : Intercept the CPS signal and offset the signal as boost retard (6 PSI+), still the engine may see that the crank is not phased with the cams sensors and trigger a CEL and limp mode, if below 6 PSI leave timing in full advance, use higher octane fuels instead. I'm sure that if I think of it some more I will find even more stuff and the ECU will fight back any abnormalities, it may even datalog and blow the warranty, if someone care :D Edit : I told you I'll find something else lol, the EMS may be able to compute that the TPS and MAF signal are out of wack and trigger limp mode again. Testing testing testing... |
#3 | |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
anyone know the measurments of this IC? whats the max our engine bay will allow without serious cutting?
measure your lower grill
glad to be of service, Mr Tamago.
Sincerely, Mr. Obvious
rarer than JDM -1 of 1!
Bathroom + Laptop = <3
lol and please don't buy a super huge IC thinking you will gain more, im using one that is around 12x10
#13 | |
ok thanks thats all i was trying to figure out.
http://members.optusnet.com.au/loxy/...cooler/bov.jpg
You tell me! ;) We'll play a little hidden object game |
#16 | |
![]() ![]() ![]() Drives: 08 toyota yaris LB Join Date: Oct 2008
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
So is this another project gone MIA?
WE NEED UPDATES CDYDJDED!!! Then again, it's been a month since the thread was created again from the hack.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
| Under $2500 Tubo Kit Update 2 | cdydjded | Forced Induction Forum | 72 | 11-02-2008 09:44 PM |
| $2500 Turbo Kit is back to life! | bdc87 | Forced Induction Forum | 8 | 10-20-2008 09:46 AM |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| Under $2500 Tubo Kit Update | cdydjded | Forced Induction Forum | 16 | 08-26-2007 11:05 PM |
| another small update on turbo kit. | joey1320 | Forced Induction Forum | 6 | 08-23-2007 04:51 PM |
